Question about 2wire 2700HG-B Router (2700HGB)
  • robertochevy May 07, 2009
    i have the 2701hg-b and can't turn on the wireless green light. i went into the 2wire page looked at the status but it says "disable" when im not even using wireless. it says ethernet:1 wireless:0 but with a "disable" button on the side.
  • 14 Answers
click in Home Network and then in Wireless settings / Enable
Please check this screenshots
Posted on Jan 14, 2009
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Hi i have a 2wire gateway 2701HG-B modem I used for AT&T DSL internet. I moved to a location where I cant get AT&T. Is it possible to use this modem with centurylink for internet?
Hello, if centurylink is a DSL service, than you can use it for internet. It appears that Centurylink is a DSL service depending upon which service you get from them. In that case, you can use it for their service.
Thanks for using FixYa!
Aug 15, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
2Wire gateway is on and the DSL light keeps flashing. All eqpt is showing that it is connected to 2wire, but not internet connection. I keep getting athe message that broadband is currently...
the problem is with century link.. There server could be down because of some maintenance.. Wait for a while and it will start working as soon as the server is up..
Engr Aamir
Jul 02, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I have a 2701HG-B gateway furnished by AT&T DSL I want to change to wireless\r\nWill my gateway work with wireless? I will have to install wireless cards in my computers what do you recommend? My...
You need a wireless router for you to use Wireless connection
I recommend DLINK, Belkin or Linksys router any of those will work.
you can still use wired connection because router has 4 ports for wired connection but if you prefer to use wireless then you need to buy USB wireless network adapter.
Sep 06, 2010 | 2wire (2701HG-B) Wireless Router
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 20, 2010 | 2wire (1000-000057-000) Modem
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Ethernet Light
the wireless light should flicker indicating it is sending a wireless signal out to a reciever.
If you have security for the wireless router so nobody else can connect without permission enable it or turn off the wireless signal if not using it.
Aug 29, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
1,556 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
