On the 7901, i am trying to install a new Rt. elevator arm (the old one broke) what is the correct procedure for installing this part? thanks in advance, -miccer
Take off the top cover, then you can replace the elevators, they come both sides in a package, part #2000010. When you replace the top cover, check all tubes to make sure they are routed right so as to not pinch one when the cover is locked down. Also there is a piston that attaches to the bottom of the smart mix valve and that the smart mix knob is on the water setting, then put cover back in place and don't over tighten the screw.
