Question about Kenmore 24032\24036 Top Load Washer
Drive tube replacement problem Kenmore 70 series
I found the retainer clip on the floor last year, had no idea where it came from. The motor coupler finally went out. I broke the washer down to repair and discovered my original drive tube did not have the groove on the bottom to hole the retainer clip. The plastic piece that works the brake was shot as well. I found a new drive tube with brakes and all to install. I installed the new motor coupler and began the reassembly process. When I get to the point of installing the basket, the nut that holds the inner basket does not seem to be able to go down as far from the top of the transmission shaft as it did before the repairs. I checked the length of the new drive tube and it checks with my old one, it is slightly longer since it has the groove at the bottom for the retainer clip. When I try to install the basket, the nut can not go down far enough to allow the length of spline above it to be able to install the agitator. For some reason, the new drive tube is not low enough on the drive shaft of the transmission. I disassembled again to see if I missed anything, but did not find anything. Please Help.
  • 640 Answers
Ok the only way i can help now is start fro the begging ok,,check point 1..im taking that unit is apart..ok...first you took motor mount plate off and change couple,,now you remove a silver gaurd over the clutch brake assm,,next is a brass u shaped clip..now you have the clutch brake asss..theres a c shape pin holding the clutch to the top of the gearcase..remove now all you have is the gearcase,,put the new one back together in reverse order..where good there ok..now if you already removed the to inner basket withblock drive..you can pull the drivebasket out,,(spintube)...now note this when putting back make sure you drivebasket goes up first and all the way,,next push your transmissin and clutch assmm,,up nice and smooth make sure that the brake spring which is inside the clutch doesnt hit the plastic cam on the bottom of the drivebasket..now replace you three boltsin the transmission...go back up too the top of the basket drive and put your drive block back now on top the basket drive theres to little pins and on the drive block theres 2 groves knock your driveblock down slowly and make the block go down through the pertruding pins of basketdrive,,until you get a snug fit,,now put your basket back,,,tightn down spanner nut,,,onthejob..keep me posted
Posted on Jan 17, 2009
Model 22748 kenmore 70 series washer. fills but
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92274800&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
It is also likely the source of the burning smell.
(Sears price $18.86 but available from most appliance repair shops)
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Apr 22, 2010 | Kenmore Washing Machines
Kenmore 70 series washer fills w/H20, but doesn't agitate or spin
Fix it. Very easy fix and the part is not expensive. What you have is a direct drive motor. For ease of maintenance the machine is made in a way which makes it possible to service it in place without having to move it. You flip the controls up and pop the retaining clips in back, unplug the lid switch harness and tip the case towards you an out of the way. You can now access the pump, motor, and that pesky drive coupling. These do simply wear out but they usually will go if a comforter is washed in it or low water big load scenario.ea74271.jpg
I have videos repair manual,parts locaters and repair photos: HERE
Feb 14, 2010 | Washing Machines
Kenmore 70 series washing machine that has a terrible smokey smell. Now my clothes have that horrible smell. What could the problem be and is it worth fixing.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load direct drive whirlpool / kenmore washers use a Motor Coupler between the motor and transmission.
The coupler consists of two plastic pieces with a rubber piece between them.
If the plastic pieces are broken, you may be smelling the rubber piece "burning"
Following is a description of how to access the coupler and check it.
It's a relatively inexpensive piece and is designed as a fail safe between the motor and transmission.
It's very easy to replace if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Nov 25, 2009 | Kenmore Washing Machines
Washer won't spin
Hello Friend, Your solution is very simple. You need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
Jun 27, 2009 | Kenmore Washing Machines
Kenmore 70 series
The following link explains how to replace a pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
The pump is only held in place by two retaining clips. Once the clips are removed, the pump (with hoses still attached) pulls directly off the motor shaft. NOTE: If the pump is leaking, it is NOT repairable and requires replacement. These pumps are sealed units. Replacements can be ordered on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offere competitive pricing so shop all three for the best price. If you require addtional assistance, please let me know. I hope this helps you.
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
Won't spin
Remove the water pump by removing the two retaining clips. You do not have to remove the drain hoses. Just push the pump aside with the hoses still attached. Disconnect the wiring harness from the drive motor (good idea to unplug the washer before you attempt this). Remove the two stay screws on the retaining clips for the motor. Once the screws are removed, take a flat blade screwdriver and gently pop the two clips from the drive motor. Remove the bottom clip first, then place one hand under the motor before releasing the top clip. Be careful, the motor has some weight to it. Directly behind the motor is the motor coupling. There will be one plastic three-prong piece attached to the motor and one piece attached to the transmission. A black rubber bushing connects the two halves together. Look for rips or tears in the rubber bushing and/or broken pieces from the coupler. I hope this helps you.
Sep 11, 2007 | Kenmore 22932 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
464 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
