Presario r3000 cd dvd not installed
Hello sir, my laptop says i do not have a cd dvd drive installed when i go into the registry like u recommmended i cannot find neither upperfilter nor lower on the right detail pane.Do you know how i can fix this?
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
My CD/DVD drive does not work
have you changed the cd and install a music cd if it still does that same thing chances are you need a new cd drive
Mar 12, 2009 | Compaq Presario R3000 Notebook
Presario r3000 too slow
I have a R3000 and after many years of usage many things happen and add to your hard drive. It can be a number of things from not enough hard drive space for your cache file to bad installed drivers.
I would suggest a full format and install using the backup disk that Compaq sent with the system. You should have the WinXP code on the bottom of the computer. This way you get a 100% clean system. You will have to reinstall any additional software such as MS Office or your virus scanner.
Hope this helps
Dec 13, 2008 | HP Laptop Keyboard for HP Compaq Presario...
My presario R3000's combo drive no longer wants to burn dvds
Try a different Brand Of DVD Maxell Typically Work Universally With Failing Drives or older Drives or touchy drives...
Nov 17, 2008 | Compaq Presario R3000 Notebook
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 08, 2008 | Compaq Presario 1200,1600 (297657-001)...
MY LAPTOP CD/DVD DRIVE DOESN'T WORK
check the registry
click start > run > type regedit > click ok.
In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
In the right pane, look for UpperFilters and LowerFilters, right click each of them and then click Delete. (If you only see one then that's fine).
NOTE: Make sure not to delete anything else or else your system will not boot to windows.
After deleting upprer and lower filters, exit from the registry editor and restart your system.
Check if your cd/dvd drive is working.
Aug 22, 2008 | Computers & Internet
CD Drive will not work
the drive is probably broken. replace.
Nov 16, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
