Question about Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System
I'm in trouble... blew my UPS :(
Hi agentsmith, A couple years ago, I swapped the original (7A2) battery for a car battery and had to be careful, because I measured some 90V or so, between the housing and battery terminals. It all went good until the day I accidentally misplaced the setting on my multimeter; instead of the voltage measuring setting, I had it on Amp setting. Result: It shorted the circuit, the house fuses went off and now my 525bt only works via battery supply, running only about 5 minutes after switching on the main switch of the unit. The 5 fuses of the unit are all O.K.; nothing looks burned. I'm a fourty year experienced hobby electronics fan and would need a circuit schematic to find and repair the damage. In the worst case I thought of powering the unit via two 13V/4Amp transformers in (parallel phase)via a bridge rectifier, a 60oooMF/16V electrolytic capacitor and an automotive relay, switching over to battery PS in case power failure. The only problem I then would have is: how to get rid of that timed 5 minutes automatic turn off cycle??? It must be in that IC or is there a timing cap responsible for it? What to do? I would greatly appreciate some advice on that. Maybe I'm able to reward you for your good advice with offering you some joy with my musical twitter-talent? ( http://www.live-styler.de/home/images/jj... ) I'm a retired (66) living in Chile and we got lots of power problems... My email: jdrinda@hotmail.com
  • 161 Answers
You are complicating your power problem. It looks like a surgeon that gets a cold, gets involved in his medical knowledge and decides to implant himself a heatr rate monitor. If you have a serious power problem in Chile, your best bet is to buy a UPS with enough capacity to handle the load for extensive periods of time. American Power Protection has a very good configuration tool on its website (www.apc.com).
Posted on Sep 21, 2007
APC 800 VA trouble shooting Manual/ Guide
Check the connection wires to the battery - are they loose?
Use a car headlamp check whether your battery can light it up. Usually UPS battery goes bad after a couple of years.
Aug 07, 2014 | APC Computers & Internet
Tripp-Lite #HT1000LCD. I have had this for about 5 years. Lightening struck very close to house a couple of weeks ago. Everything blew out but all the electronics were saved. However, since then every...
Your batteries would have been weak from 5 years of use. The Lightening could of blew out one of your batteries. The UPS did it's job but at a price. I would replace the batteries first then see how it works
Sep 11, 2011 | Tripp Lite HT1000LCD UPS System with LCD...
Need to locate someone to install batteries into our UPS Powerware 2000. Location, Tempe, AZ (Phoenix, AZ)
Try contacting Eaton. They bought Powerware about 6 years ago and the personnel are trained on older Powerware systems. If you have the part number and serial number from the rating label on the UPS, that would be helpful.
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Nov 24, 2010 | Exide /Powerware PowerWare 2000 UPS...
Mge ups making noise after applying coolant
If I knew the specific UPS model, I might be able to provide some better input. At this point, I would contact Eaton product support. Eaton acquired the MGE single-phase UPS line a couple of years ago and assumed support/service for these products:
Nov 03, 2010 | MGE Computers & Internet
APC 280 UPS problem. No A/C output when power interupted. Battery charges OK.
Have you load tested the batteries? DCV is not a good enough test for the batteries, they could still open right up under load. If the UPS is over 3 years old, I'd swap the batteries. Your power is drawing solely from the batteries on AC line loss, so if the UPS is failing when that occurs, almost certainly is the batteries.
Aug 20, 2009 | APC INTERNATIONAL BACKUPS PRO 280...
UPS power goes off instantly as soon the external supply stops.
In our office, I have had to replace UPS batteries AGAIN two years after I replaced the original batteries in the units. I had purchased the replacement batteries locally, so I don't know if the brand of replacement batteries was not as good as the original batteries or what. But your weak battery light is not flashing ... I would try a replacement battery (if it isn't too expensive) but I know that some of the older batteries are no longer used in the newer UPS units so if the problem wasn't the battery you are stuck with a new battery and nothing to use it for.
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
Power keeps going on and off
I have the same problem.
It is most likely the battery.
I tested my battery on a Shumacher trickle charger, and the battery wouldn't hold a charge.
This is a common problem with UPS systems that use sealed lead acid batteries.
The longest life that you can expect with these types of batteries is 5 years MAX.
The battery can be replaced with a Radio Shack 12V/7200mAh Lead-Acid Battery
Model: CNB-GP1270F2 | Catalog #: 23-9030
Here is the link for the UPS users manual.
http://www.cyberpowersystems.com/user-manuals/CP550SL_UM.pdf
To replace battery, (unplug AC cord), turn the UPS upside down on floor or workbench.
Remove the 6 deeply recessed phillips screws, then pull the bottom off.
Remove the wire leads from the old battery (pull on the connectors, not the wires). Install new battery (red wire to red or + sign) and replace the bottom and screws. Careful, tighten the screws finger tight (plastic strips easily).
Plug in UPS and you should be good to go.
Hope this helps
Jun 07, 2008 | CyberPower 525SL (CPS525SL) UPS System
UPS
All UPS uses some sort of battery to power the unit in the event of a power outage. Like car batteries they also have a life span which can be a couple of months to a year or so. If the UPS has been in service for some time, perhaps it simply needs a replacement battery. On the other hand, if the unit is fairly new and carries warranty, it may be to your advantage to consult your dealer and claim for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Opti -UPS PowerES 650 UPS System
I have a Compaq T2200XR UPS, the battery is out, it shows a battery with and X, my question is, Is it going to shut down or it will keep passing truw power with no battery until I get a new one in 2 or 3...
Wait till you get the new batteries........, then swapped them out.
The answer is yes, until you have a blackout. oops.
You have something..... so
By the way give me the battery information and I will send you batteries. Be happy to sell them to you. I may quote yoiu a better price then anywhere else.
Call me 727-823-6100
Good luck.
Dec 03, 2007 | Compaq UPS T2200 XR UPS System
Open Questions:
Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System Logo
110 people viewed this question
Top Opti Computers & Internet Experts
galvinfranks
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Power & Systems...
Power & Systems...
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
