Question about Jenn-Air JES8750 Electric Kitchen Range
The oven door squeeks
When the range is off the door doesn't squeek. Once the stove heats up it is very loud opening and closing. We have tried numerous products to oil the door down.
Help
    Scholar:
  • 89 Answers
Lol sounds like its not just a lube problem but an alignment problem. alot of times the hing has a nylon bushing to cut that noise out. might just want to remove the hing and replace it or try to find a new bushing. these type of problems really ****. seems simple to fix yet it offten takes months of trial and error to cure the problem..... good luck
Posted on Jan 14, 2009
Tip
How to stop a squeek
For fixing A squeek on your fridge door/kitchen doors/stove door/microwave/or even car try this and save money.We all have cooking spray and if you don,t buy some before the hardware store sells you something that will cost A fortune.Just spray A small amount on t5he squeek and open and close it 4/5 times. If it is hard to get at use A small paint brush.This can also be used on all most anything even your car but only in the summer because it will freeze.Now the squeek is gone and you can use the rest for cooking no waist.Thank you and good luck....
on Sep 25, 2014 | Oops Cleaners Ready To Use Spray 500 Ml
Noisy oven door hinges
Spray the hinges with some spray lube. This should help.
Dec 05, 2013 | Jenn-Air Ovens
Kitchenaid oven troubleshooting
it sounds like the heat escaping from the door damaged the electronic control board part number 8186393 and sears has it for 200 dollars.the way the door was left open was directing the heat right at the computer board and you sholud never use the stove for heating the room or things like this happen
Nov 20, 2011 | Kitchen Ranges
Squeeks!!! When the door opens or closes it squeeks very loud. WD 40 and other similar products have nott helped.
WD 40 is a water displacement formula not a lubricating product.
Try a oil hand pump with some light engine oil on the henge directly.
After a few days this should help.
Hope this tip helps.
r/
David
Jan 23, 2010 | 2002 Oldsmobile Alero
After self cleaning cycle, oven door will not open. the lever won't move.
in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
all too common with self clean ranges.
unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
i see this at least once per week
Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Sounds like drum squeeking, have to open and close front door to get even one page to print
There is also the fuser unit that need regulare servicing because the majority of the squeeking comes from the fuser unit because of the generated heat.
Good luck
May 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Jenn-Air JES8750 Electric Kitchen Range Logo
105 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
