Question about Yamaha RX-V363 Receiver
Cannot record from TV (RX-V363 & LG RH399H HDMI DVR)
I have a Samsung HD TV, HD PVR (Cable TV Receiver), Yamaha RX-V363 & a LG Video Recorder connected as the RX-V363 manual recommends. Everything works, except when I try to connect the video recorder as a DVR. Connected to the DVD ports, playback works. Problem is, when I connect to the DVR in/out audio ports, and turn the input on the Yamaha to DVR, it says I must check the signal cable? What am I doing wrong? Jakkie
tech48
  • 624 Answers
SOURCE: Yamaha RX-V663 Not Providing 1080 Signal
First let me say that you have stated your problem very well. I completely understand the issue you are having.
I have been repairing a/v systems since they started selling them.
By your description of your problem, it is obvious that you have isolated the problem to the Yamaha.
Despite what Yamaha tech support say's, it is their problem.
I have been dealing with tech support for a lot of different manufacters for many, many years. I repair under warranty over 20 different brands, but not Yamaha. I have repaired plenty of Yamaha receivers but none with this particular problem.
It is not uncommon to find tech support people who don't know as much as they should about their own product.
Since I don't have the instruction manual or a service manual forthis model I can only be of minimal help.
What you can do, if you have your instruction manual, check it over closely for this subject on how to change the settings for the HDMI. If you can not find this particular issue, it is possible that the Yamaha doesn't support 1080i. I would be surprised if it did not, but stranger things have happened.
Another thing you can do if you can still not find an answer to this problem is to take it in to an authorized Yamaha service center.
If you have recently purchased this Yamaha, it will be under warranty. They get at least 1 year. Tell them the problem you are having and if they do not know how to solve it right there on the spot, or give you an answer that satisfies you, leave it with them
to have it fixed. If they are an authorized service center they will have to fix it or get it replaced for you if it is under warranty. It may need a firmware upgrade to the digital board. If that is the problem, then they can do it for you.
Let me know if you need any more help.
Sorry I wasn't more help, but an authorized service center may be your best bet.
Posted on Jun 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Yamaha RX-V363
There is likely a static charge (voltage / difference of potential) between the the receiver and the TV.
They should have their grounds tied together. This should be covered in your owner's manuals.
In some cases, there may also be a stray voltage on the cable line's ground. If grounding the two together doesn't work, you may want to call the cable company (or you or a friend may be able) to check the cable line for a stray voltage or bad ground.
Posted on Nov 08, 2008
SOURCE: No audio after hooking up RX-V363 to TV monitor (from cable box )
The HDMI on the RX-v363 does not pass the audio.  You need to either connect an optical or digital cable from your audio source.  If it is a cable box or DVD player there should be audio outputs in addition to HDMI
Posted on Dec 31, 2008
SOURCE: I have a Yamaha Rx-v363
you only have to thange the setting for hdmi from stereo to surround
Posted on Jan 02, 2009
petraman7
  • 1175 Answers
SOURCE: Wii to RX-V363?
Hi..
If youre talking about the set of 3 A/V plugs in the front then you need to connect to the Video Out (yellow) plug in the back that says something like "Front Video" or "video 3" out. Connect that to the display.
Posted on Jan 14, 2009
I have a Yamaha RX-V340RDS amplifier and need to know how to connect my tv, dvd recorder and hd-pvr
manual found here: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RXV340.pdf
Mar 23, 2014 | Pioneer VSX-D608 Receiver
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Wii to RX-V363?
Hi..
Jan 14, 2009 | Yamaha RX-V363 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
Dec 24, 2008 | Yamaha RX-V463 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V363 Receiver Logo
156 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
