Question about Polycom ViewStation ISDN (pcy220011323001) Video Conference
Hi, i have a polycom which is running now. Now i have to collect the mac.cfg file of this polycom. how do i get this? previously i had server based access, so that polycom will get the config file from the server. but now i just need to have the config file. please help.
    Problem Solver:
  • 7 Answers
Try FTP
Posted on Jan 14, 2009
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
Coult not using boot server error loading 0004f217b421.cfg
This occurs when the phone is set up to load it's configuration file from a ftp or tftp server and it cannot find the file or server location. If the phone is supposed to do this, please check that the ftp or tftp service is running on the specified server. The server name or ip is specified in the setup of the phone, available when the phone is first booting up. The default username is 'Polycom' and password is '456'. If you DO NOT want your phone to get it's configuration from a network server, enter the setup area and remove the server name or IP address from the appropriate section.
Feb 04, 2011 | Polycom SoundPoint 330 IP Phone
Reset password
Plug the phone in and allow it to boot up. Once the home screen is displayed, press and hold the 4, 6, 8, and * keys for about three seconds, or until you hear an audio alert and the phone asks you for a password. Enter 456 (default Admin password) and the phone will default itself. If the password has been changed, and 456 does not work, enter the MAC address of the phone as the password. Entering the MAC address of the phone will only reset the Admin password to the default, so it will probably be necessary to repeat this procedure, entering 456 the second time, to factory default the phone.
Dec 04, 2009 | Polycom SoundPoint IP 550 IP Phone
I has polycom soundpoint ip33, while booting its giving error " error loading 0004f220429c.cfg" and its not booting at all.pls guide me how to fix this problem.
Can you pls check the configuration file on the tftp server
some wrong information is there
pls compare with any other ip phone
Oct 30, 2009 | Polycom SoundPoint 330 IP Phone
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Need advice on installing a Polycom 'Polyscan' video teleconferencing system
Some ideas based on your post/description:
It is very possible that the management/support software necessary to run your videoconferencing system resides or is installed in the PC based router that got burned. When you replaced the router with a NetGear, you simply provided an interconnection/distribution/forwarding/sharing of your Internet access to the different PCs of your firm but nothing to replace the server/management software for the Polyscan System. You have replaced only half of the PC based router - the router only, hence you have Internet acces but no video conferencing which is software managed which was installed in the PC half. Additionally, Polycom uses online Product Activation which might be necessary for your system to start working again.
Depending on the model of the Polyscan System that you have, it is also possible that you simply have to reconfigure the network settings of your Polyscan' System to match the new IP address of the Netgear (which might be very different from what the burned PC based router was using before). I understand that Polycom have several models (or series as they term it - PVX, TPX, RPX, VSX, HDX, and others). Would you pls post back with the series/model number that you are using?
Have you tried discussing your concern with Polycom Support? They might be in a better position to address this.
Hope this be of some help/idea. Pls post back with the Polycom system model that you are using.
Good luck and kind regards.
Nov 28, 2007 | Polycom (2200-30169-001) Router
Polycom ViewStation ISDN (pcy220011323001) Video Conference Logo
178 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
