Question about Brother HL 2140 Laser Printer
Hi sir this is Muhammad i just boiught new brother printer what easy step is that i can start my printer i install already but it's not printing anything plz help me, thx
  • 741 Answers
You have to install the drivers for your Computer to recognize your printer. Sometimes this is done automatically with Plug n Play but it depends on the device. Load the disc that came with the printer, this will load your drivers. Then click on Printers on the desktop and click add new printer. This will solve your problem.
Don't forget to rate this solution.
Posted on Jan 14, 2009
Says printer error...wont print
Sir/Madam
If Your Brother Printer Not Print Then Please Go To Official Brother Printer Website To Perform Below Step :
The printer status is Offline or Paused For Windows Brother
If your question was not answered, please check...
Or
Still Having Brother Printer Problem then Follow Us For On :
Jan 19, 2014 | Brother HL 2270DW Laser Printer
Print head cleaning
Sir/Madam
It's Very easy To Solve 1 PointsProblem with Brother Ink for Dcp145c Lc-980.All You Need To Do Is Watch The Below Video And Follow the Step Shown In www.youtube.com/watch?v=ngVCcuONboI,I Hope After Watch Video You Fix yOur Brother Printer Problems,
Or
In Case You Still Need Our Help The Follow Us For
Brother Printer Support
Jan 23, 2013 | Brother Ink for Dcp145c Lc-980
My officejet 6310 all in one printer has nt been working for past several days the report states that spooler has not running
Hello Richard! Welcome to FixYa!
If the printer report states that spooler has not running then there are few steps which fix that problem. Follow the given steps carefully:-
Click Start of your PC and open the Run Command and type the command as "Services.msc"
Then scroll down to print spooler services, Right Click and and select Stop
Now delete all your Print Jobs which are in pending status
Now go to C:\WINDOWS\system32\spool\PRINTERSand delete all the files or folders listed there, Now you can try to return to the Services.msc and start the print spooler service to see if this has been fix your problem
Be sure to stop the print spooler services before proceeding. First you must remove the corrupt drivers manually from the windows registry.
Delete your printer driver, now try to enable print spooler service again and Uninstall the Printer Software installed in the PC, Now again install the printer driver and software.Your problem will be solved.
I hope this solution helps you and you have a clear picture in your mind. Let me know if you have any confusion.
Sir, Your Rating as Five Stars and Words of appreciation will be esteemed.
Thank you for taking my service
Concerned: Muhammad UzairTeam : FixYa
Dec 16, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Printer will not print color. All ink cartridges are Canon, and all printer settings are set to color. This printer has had no problems with color before. When I perform a nozzle check no color prints.
Hello and Welcome to FixYa!
Sir/Ma'am i know the solution of your problem, It can surely solve your problem, But before i give you solution i saw that you have already returned your money back, Kindly Re-Take my service, I will surely help you on time now.
Waiting of your positive response
Thanks
Dec 13, 2011 | Canon PIXMA MP780 All-In-One InkJet...
MFC 6490 CW I installed new colour cartridges, cleaned heads but it wont print in colour???
Hi I'm sorry say your machine will need a new print head and they are not easy to fit my suggestion will be to contact brother by email and ask if they will suggest a repairer in your area
but I would look at replacing it with a canon or a hp
Mar 08, 2011 | Brother MFC 6490CW InkJet Printer
My brother hl2140 won't print. Yes - it is on and plug is secured. I have attached this printer to a new computer. I have gone into control panel and the hl shows that I have 7 documents ready to print. ...
Try this. Cancel all the documents that are waiting to be printed in the control panel. then delete the printer int the control panel. Click here to go to brothers website to download the correct driver for your operating system. Install the driver you downloaded. While installing it will ask you to plug the USB in and to make sure that the printer is on. When you plug the USB back in make sure that it is in a USB port that you have not plugged it into already. and you should be all set :) Best of luck to You :)
Dec 27, 2010 | Brother HL 2140 Laser Printer
How to switch from "offline" status to "online" status
I was also facing the same Problem, I solved it by following these steps
First I noted down the IP address from the Printer, Menu > Network > Wlan > Tcp/IP
then on my pc
1.Point to Printers and faxes 2.add new printer 3.a welcome window appeared click next --select local printer attached to this computer do not check automatically detect............. then click "Next" 4. Point to Create a New port then select HP Tcp/IP Port 5. a Welcome page appears again click Next 6. Now is the time to Write the IP address you noted earlier from the Printer also check Always print to this.......... 7. now by clicking ok or Next it will take some time to load another window 8. Now at the bottom left of this window you will find two options i selected the "custom" option, another window appeared click ok and wait for few seconds, when that disappear click Next Click finish and wait.......... 9. Here You go another window appeared Point to the Manufacturer Brother and then select the model MFC6490 10.Click Next and Point to KEEP THE EXISTING.......... or whatever option you like.. Now its easy follow the on screen steps untill you are asked to PRINT A TEST PAGE
NOW YOU ARE CONNECTED AND ONLINE AND ENJOY....
BUT HAY THE OTHER DAY I FOUND THE SAME PROBLEM "YOUR PRINTER IS OFFLINE" DON'T WORRY, i SOLVED THAT TOO 1--GET TO PRINTERS AND FAXES 2--SELECT THE PRINTER WHICH IS ALREADY INSTALLED AND SAYING " OFFLINE " 3--RIGHT CLICK AND POINT TO "USE PRINT ONLINE" THERE YOU ON FLY AGAIN!!!!!!!!!!!
THANKS MUHAMMAD IMTIAZ KHAN
Apr 02, 2009 | Brother MFC 6490CW InkJet Printer
DCP-110c wireless printing
You need to purchase a NC-2200w print/scan server to attach externally to your printer:
Here is your printer's manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_DCP_110C_EN_2.PDF
ManuaI /installing the NC-2200w print/scan server:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/printserverw/nc2200w_all.html?reg=us&c=us&lang=en&prod=nc2200w_all
sold here, or from Brother authorized dealers:
http://www.nextag.com/nc2200w/shop-html
Please remember to rate all Techs who assist you for free :) Good luck, Joe
Jun 07, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
