Question about Intel D845WN (KD845WNPAK10) Motherboard
Computer moth erboard
Wheb i was on my computer there is no display in the monitor and i cheked my in the shop he said there is everything is correct in ur computer but motherboard is not properly working so plz solve my problem
  • Anonymous Feb 03, 2009
    my not display in BOOT Configuration. error occur on (ENTER F12 BOOT FROM THE NETWORK). i not insert in harddisk only check the mother board
    New Friend:
  • 40 Answers
Try getting a new motherboard or adding a graphics card to your existing one. Those are your only options really if you motherboard is bad. Sorry
Posted on Jun 13, 2007
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
"Input not supported" even though it appears to be displaying correctly.
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
Apr 21, 2015 | Planar Computers & Internet
What is the difference between a bug and an error
The first physically documented computer bug was documented by Dr. Grace Murray Hopper when she was programming the Mark II Calculator (computer). When the system was not functioning correctly after troubleshooting the system, she found a moth between contacts of a relay. After removing the moth the system functioned and the moth was taped in her notes documenting the bug.
A computer error is displayed when a known problem in the computer code (program) expects a result from the hardware (electronic circuit) or software, and it does not fall within the code parameters. In most cases the error can return information about why the computer had a problem.
Conclusion:
A bug is an unknown failure of the system which usually is intermittent and causes the system to crash or results in some type of failure. An error returns information about the system failure which is displayed or documented on the display or in log file.
Jul 02, 2010 | Contax Cameras
CHEK YOUR pc OR SIGNAL CABALE
You should Check monitor on different system, after that, although if your monitor is ok then you should check your display your System (CPU) restart the syatem and check display in Key-board by pressing Num Lock Key whether on or off, if key is not working so problem in your system not in Monitor, check then reply
I hope that this has been very helpful for you
Dec 01, 2009 | AOpen A75P Monitor
I can't use the correct resultion for my 22' screen.
check for higher resolution on your video card, check settings on display.
Jul 16, 2009 | AOC 22" Widescreen LCD Monitor
Cd burner
this is most likely caused by faulty hardware or a driver problem, I would suggest you have a tech look at the pc since this is not easyly solved with text only.
Jun 12, 2008 | AOpen A75PF Monitor
Intel D845WN (KD845WNPAK10) Motherboard Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
