Question about ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card
White screen with radeon x1300 pro agp 256m
Uninstalled factory video drivers, loaded 8.12 catalyst pkg. and get a blank white screen. any ideas?
    President:
  • 2,351 Answers
Hi porkchop_66_ , if you uninstalled factory graphics drivers, chances are you uninstalled the motherboards built in graphics card driver. Since you haven't provided your motherboard model & manufactures name I can't be 100% your weren't using an onboard graphics card. So I'll cover both.
If you added the X1300 AGP card, (Not replacing an older AGP card), you'll need to enter the motherboards bios menu & set the bios to boot to the AGP slot. If you replaced an older AGP card, its possible you have the monitor plugged into the wrong VGA out-put on the Radeon. There are two ports. One DVI & one VGA. Try each & check for display. Lastly, the Radeon X1300 card you have
runs in an AGP port that supports 1.5volts. Check your, motherboard manual. Check if your motherboard supports AGP cards of 1.5v.
If all this does not make sense, post back with your motherboards model number & the manufacture name & I'll be able to help further. Post here.
Good luck porkchop_66_!
Thank you for using fixya.
Mike
Posted on Jan 14, 2009
  • Mike Peluso
    Mike Peluso Jan 16, 2009
    If you did not find this helpful you should have said so. There are more options to fix your issue but I'm not wasting my time.
I have a Dell dimension 4300 running Windows XP SP3. The system has 1 Gb of RAM. I removed the AGP graphics card that came with the system and installed the VisionTek Radeon 256M X1300DMSPCI card into a...
Yes, it is compatible, just that you must first uninstall the previous video driver, then configure the BIOS to route the video signal to the PCI and not the AGP and only then install the new card. And in the end it will behave worse than the previous AGP card you got because the PCI interface is way slower than the AGP.
Just buy a good AGP card, PCI cards are made for office pc's in which the onboard one is totally obsolete.
Feb 08, 2011 | VisionTek RADEON X1300 , Graphic Card
When i put my AGP ati radeon x1300 video card in it, it makes a blank white screen, any help
Have you turned off any onboard video card that is running??
if not go into the bios(f10 when you see the startup screen) and go to video:agp
If this is not the case try a older or newer version of the driver. Start windows in safe mode and install it that way.
remember that you can always start windows in safe mode even if your graphics card is not working as it will run in software mode instead.
Mar 16, 2010 | Medion MD-1768 PC Desktop
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Im running an ATI Radeon x1300/1550 pro graphics card(256m) .. on OS win XP (sp2) all up to date drivers and DirectX9 but wen i try to play any on line game i just get a white screen i get sound but no...
- does it work properly when u disable the online game feature (play the same game without just on your PC or in LAN-session)
-goto network connections and disable every connection available besides the one u use for internet access
(as u can wire up video cameras
to the card via the 1394/port, this port may have been recognized as network adaptor in windows, this might cause IRQ problems and as u do not use it, it is wise to disable it)
retry now the online game / if stil the prob, came back to fixya!
good luck
Aug 08, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
No driver disc
http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.4.1&product=2.4.1.3.7&contentType=GPU+Download+Detail&ostype=Windows+XP+-+Professional%2fHome&keywords=&items=20
Here is a link to the factory site with the MFR's driver on it. If I have not selected the correct OS you may need to change it, but this is exactly what you need.
If this does not work or you require further help feel free to contact me, I CAN solve this problem.
Jim
Aug 05, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Low brightness on second monitor using Radeon X1300 video adapter
According to the X1300 specifications here it does support multiple displays. The option to configure the display is found in the Catalyst application. Do you have the latest version of that? You can get it from their website.
Jun 01, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Graphics driver for x1300 pro agp
Yes it will definetly works;-) go pro go ati:D
Jan 05, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
HIS Radeon X1300 Misdetected
do the BIOS update !
in the advanced BIOS features there should be a onboard GPU tab, put it on disabled or on initiate AGP/PCI first (depends on the BIOS), so to be sure that the onboard card is disabled !
Connect the display to the HIS ...video card , and at least on bootup there should be info displayed on the screen . If not than : - try to reinsert the video card (bad connection ) (also check if its a card that needs external power source ( i doubt it))
- check if the video card is compatible with the motherboard (should be in the user manual, or on the producers site ... )
- check on another comp. if the card is good ....
hope it helps u ... if not, give more details ....
Jan 21, 2008 | HIS X1300 RADEON X1300 PCIe 512MB (128 MB)...
ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card Logo
314 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
