Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Keypad locks up
It turns on. but cant dial or answer
  • 28 Answers
It sounds like you might need a new keypad. Keypads can get damaged or worn out. They can also be replaced. I have never done it to my K1 but I have replaced a lot of Motorola V3 keypads. It is more affordable than buying a new phone but you will be without your cell phone while it is being repaired.
Sorry, I forget that I have always repaired my own and so I don't know how much a shop would charge you to replace it.
Posted on Jan 15, 2009
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Can't push one button to lock anymore
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Left soft key flashes blue, cant enter more then three numbers, unable to dial in number (not recording or responding) cant access history or contacts
Your keypad is locked .. You can remove the lock.. Can you specify your brand and model number of your cellular phone so that we can help you out.
Feb 21, 2011 | Cell Phones
When dialing using speed dial my keypad gets locked or muted. Cant use speaker and nobody can hear me?
When electronic devices start acting up, 99% of the time a firmware rewrite solves the problem. May I suggest upgrading / replacing the system software of your BlackBerry Bold 9700? The latest BlackBerry Bold 9700 system software is available through here.
Jan 19, 2010 | RIM BlackBerry Bold 9700 Smartphone
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
Keypad locks too frequently when retrieving voicemail
go into your settings and set it to a longer locking setting.
Dec 25, 2008 | LG KU990 Viewty
Lg envy 2 dialing while in my pocket
you need to go to menu then settings then security then keypad lock it should ask lock now or auto lock wich will lock keypad after about 30 seconds with no activity,after locking keypad when you push a button it should tell you to push somthing like menu star to unlock this should stop your phone from dialing in your pocket
Sep 24, 2008 | Cell Phones
Keypad is frozen, cant dial out or recieve any calls
PSYCHMAJOR - take the phone back
guest - replace the flexcable
Sep 21, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
