Question about Admiral AW22 Top Load Washer
Washer spins agitates, but will not drain
I have an Admiral washing machine model LNC6760B71 It will agitate and spin, but when it reaches the drain cycle the machine goes completely dead-no noises, no nothing. Looking at the underside, the motor is not turning. Does this machine's motor turn one way for agitating and spinning and the opposite direction for draining? If so, could I have a burned out motor? Also, how do you get the front panel off this thing? I'm darned if I can figure it out! Thanks! David B.
    President:
  • 1,294 Answers
Possible your outlet filter is blocked; find out where it is from your manual, clean it out and re-fit. Also try the spin only function to see if it drains.
Posted on Jun 13, 2007
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Will not agitate
check the module that controls the agitation of the motor. It is found in the control panel and if it fails the motor has no agitation action. have a washing machine check it out.
Jul 14, 2013 | Admiral AW22 Top Load Washer
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Admiral washer will agitate but will not spin dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
Possible timer problem, timer reverses motor to agitate this is not hapeniing, check timer or wiring to motor.
Nov 02, 2008 | Admiral AW22 Top Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
317 people viewed this question
Top Admiral Washing Machines Experts
Sal De
jimorris77
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
