I have a Kenwood KDC-C712. The face plate read "E-99" whilst changing a cd, then i tried to eject the magazine, but it wont come out when i press the button on the changer. The part that pulls out the cd's from the magazine moves a little, then moves back again. The unit humms a little when this happens.
Can i fix this myself?
thanks, i just have to get a screwdriver small enough to take them out. I'll let you know how it goes tomorrowthanks, i just have to get a screwdriver small enough to take them out. I'll let you know how it goes tomorrow
ok, after wrecking two sets of precision screwdrivers, i finally got the case open. The only small motor easily visible with a cog to turn does nothing. this is on the device that takes the cd's out of the magazine. The only other motor i can see is on the board over the magazine, however, there is no way to turn this. Any other thoughts?ok, after wrecking two sets of precision screwdrivers, i finally got the case open. The only small motor easily visible with a cog to turn does nothing. this is on the device that takes the cd's out of the magazine. The only other motor i can see is on the board over the magazine, however, there is no way to turn this. Any other thoughts?
You can't post conmments that contain an email address.
From the Kenwood manual:
Something is wrong with the disc magazine. Or the unit is malfunctioning for some reason. 99 E:
Check the disc magazine. And then, press the reset button on the unit.
If the "99E" code does not disappear, consult your nearest service center.
I hope the rest works for you.
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
source
http://www.kenwood.nl/support/veelgestelde_vragen/
Changer Error Codes
? E-00: Poor Cable connection.
? E-01: Magazine not properly set in changer.
? E-02: No Disc in magazine.
? E-03: CD does not have selected track number.
? E-04: Disc is dirty, upside down or unreadable.
? E-10: No data is recorded on the MD. The player plays the next disc automatically.
? E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Sounds like the mech is gummed up, jammed, or a cd is stuck inside.
Get a nerd to open it up and check it over.
Luck
