Question about Motorola Mobility RAZR V3
Voice record!!!!!!! i just got my razr. it's not knew though, my uncle gave my his old black one because he dropped this one and he wanted a knew color. well i wanted to use voice record and i hold the button down but nothing happens. can you describe to me how it works?
Go into Voice Record & Select New. Hold Down The Big Button On The Right Of The Phone.
Posted on Jul 07, 2007
Press the big side button on the right. Hold it down while the phone is flipped open. Then it should work, hope this works.
SOURCE:
RAZR V3x Cellular Phone: where are the instructions (on the phone) for sett...
to set up voice dialing on the V# first you need to record and store the names..you do this by, open up your contacts, then go to the name you want to voice dial,and record the name.then on the right side of the screen part of the V3 press the button..the rest is easy
May 10, 2010 | Motorola Mobility RAZR V3x Cellular Phone
My Razr will only accept calls, voice dial and voice record keep looping.
Your phone is water damaged. It may help to let it dry out further, but most likely it is beyond help. You could sell it for parts on eBay. People will buy water damaged phones on there too.
May 29, 2008 | Motorola Mobility RAZR V3
Help
sorry it sounds like the folder may be lost forever.once you pressed the record button, the recorder knew it as a new recording in that folder.look at it like a answering machine going out message. if you made a mistake,and you wanted to record a new message,the old message would be erased.if your folder was on a cassette recorder, you would have only erased those few seconds.
sorry
wg
Feb 17, 2008 | RCA RP5020 Digital Voice Recorder
Voice record memory full & screen froze
Are you able to get into the software to purge the voice records?
If not, it sounds like the phone needs to be "reflashed" at an authorized service centre. Take it where you bought it. It should not cost you if it is less than one year old (warranty).
Sorry I couldn't be more helpful.
Feb 08, 2008 | Motorola Mobility RAZR V3
Recording music
The phone has a Voice Record feature, but I think it's only for a couple of seconds of audio for the voice dialling feature.
Anyways, go to Menu > Office Tools > Voice Records and press the Voice button, located on the right-side of the flip display.
Nov 07, 2007 | Motorola Mobility RAZR V3
Dropped and voice recording doesn't work
You need to replace the flex cable in the screen section of the phone...You need to get your phone to a good repair shop to get this done. It's a very tedious job. Must be only done by someone who knows what they are doing.The controls for the voice recording is controlled by one of the side buttons on this flex cable. Sam !
Jun 23, 2007 | Motorola Mobility RAZR V3
Dropped and now voice record doesn't work
HI tHERE, There's a flex cable on your screen that controls the voice recording. This needs to be replaced by a service tech.They could be brought on ebay fairly cheap. It's called the screen flex cable for v3 razr. Hope this helps. Sam !
Screen won't turn on
It's very possible that your phone's flex cable is either broken or disconnected from the screen.The flex cable would have to be replaced or reconnected. The reconnection is not too bad but replacing the flex cable is a way bit tedious.I'll choose the first option to see if this works. You'll have to take this to a qualified phone repair shop. These phones are very technical to work on even for someone who knows about them. SAM !
Jun 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
