Replaced egr solenoid and egr valve and the code will not reset even after replacing ecm
SOURCE: flashes codes 12 and 32 intermittently after running rough
the 12 code is the start for the codes to be read code 32 is a map sensor code but does not mean that , i have a 91 sonoma and same codes turns out it wes my intake gaskets
SOURCE: egr failier,replaced censer and valve what next
Remove the EGR valve and look in the ports in the intake. There is a good chance they are stopped up. Good Luck.
SOURCE: has low power, surges @ cruizing speed, rough idle (code 32)
You can remove the egr and see if it has been sealing,and if it still moves.
SOURCE: 2006 gmc sierra 1500 4.3 . check engine light on.
More than likely the evaporator vent valve.
It sounds like you may have low compression in one or more cylinders, suggest you run a compression test, this should always be done when this condition exists and igintion is not source of problem. This engine also can have issues with intake manifold leaks, use a can of carburetor spray and spray around the intake gasket are to cylinder head, if a leak is present then the idle change when you hit the leak.
