Question about Dell 1815dn All-In-One Laser Printer
Message shows "fuser door open"
+ "scanner locked"
+ horrible clicking sound when turn on the printer
+ won't print
  • 741 Answers
There is a part called the "fuser" inside of the printer. Its purpose is to heat up and melt the toner to the paper. Fuser may need to be replaced, need to call printer tech. Fuser is extremely hot, 300 degrees to melt toner. Recommend call printer tech to fix.
Don't forget to rate this solution.
Posted on Jan 14, 2009
4690 MF Printer displays the following message:"SCANNER MOTION ERROR, CHECK SCANNER LOCK"
I would open up the scanner and check to see if it can move, When you turn on the machine does the scanner try to move before the code shows up.
Feb 18, 2015 | Konica Minolta Office Equipment & Supplies
Printer will not print.Screen show blinking L & 3. What does this means.
Check the that scanner lock is not on. This lock is used to hold the scanner in place when you move the machine
Feb 12, 2015 | Sharp Al1631cs Al1641cs Al1661cs Copier...
How do I clear a "door open" message when no doors are open and I have checked the door sensors?
re install the printer drivers or
reset the printer by eject the power and data cable for a one minite
Nov 26, 2014 | Samsung CLX-3175FW Multifunction Laser...
Reinstall software. You do not have to
uninstall the original software, re instalation will roll over it.
Brad
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
The fuser door is stating it is open when it is closed I have turned off and taken out fuser turned on and then replaced. still showing fuser door is open will not print or copy
That is a problem with the fuser door switch which is a part of the High voltage power supply. Replacing the HVPS should fix this right up.
Apr 28, 2011 | Dell 1815dn All-In-One Laser Printer
Can't clear 01 fuser jam
open top scanner, open inner cover where printed paper normally comes out. push left and right locks on the fuser and the fuser will come out. remove jammed paper. put back together in revers order. paper jamming in the fuser is a sign the fuser is faulty/worn o non genuine toner is being used.
Feb 08, 2011 | Samsung CLX6220FX COLMON MFC Printer
My Dell 1815dn printer - says the scanner is locked. Makes horrible clicking sound when I try to scan of make a copy. How do I unlock the scanner?
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of the printing output slot.)
This prevents the scan head from damage when the printer is moved.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 20, 2010 | Dell 1815dn All-In-One Laser Printer
Hp psc 750
Very common problem with this model, the gear that drives the fuser (the hot part) breaks. If you are not a tech I would bring it into a shop. Also ask them if they can replace just the gear and not the whole fuser. (much cheaper)
Sep 20, 2007 | Sharp AL-1655CS Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
1,065 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
