Question about Durabrand DUR-1500 Portable DVD Player
"No Valid Disc"
I have a Durabrand Dual-7C. When I load a disk, it shows "loading", I can hear it working, then it says "no valid disc". I've tried several discs, none that are not scratched.
  • irish4mark Aug 09, 2008
    irish4mark061007@localnet.com my dvd player will not load disk, anymore, just quit. and no valid disc error.
  • Anonymous Mar 28, 2009
    I have tried putting in different new dvds and none of them work. I can hear the motor trying to spin but it won't pick up the disc. I just bought this less than a month ago for my son and he's so small he doesn't even touch it so it truly is just a junky dvd player. =(
You can find the spindle motor in a wore out cd rom drive or just about any house hold electronics , that you could take it out of something else that isn't any good any more , you can find them type motors just about in anything .
Posted on Jan 02, 2008
    Scholar:
  • 47 Answers
These units are known for bad spin motors. the unit appears to be working , but does not obtain the speed needed to extract the information for the a/d converter to correlate.Unfortuneately it is not economically feasible to repair there units. I would however clean the laser just to rule out the obvious. Scrivitron
Posted on Jun 16, 2007
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Cant load disc
I was having the same problem with my pvd-702...I genlty cleaned the lens with a dap of alcohol on a q-tip. I blew the lens so it was dry and the dvd player started working. No need to try to call the 1-800 number, it is disconnected and the warranties are not valid, because the address does not exist. try the q-tip, it worked for me.
Mar 20, 2008 | Durabrand PDV-705 Portable DVD Player
Stopped working
This happened to me several times, Eventually i gave up. One day though i tried it again and it worked. You should probabaly wait a month or two and see what happens
Feb 15, 2008 | kawasaki PVS-10921 Portable DVD Player
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
No valid disc
Hi, Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional. Good luck and kind regards.
Sep 28, 2007 | TruTech PVS12701 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Durabrand DUR-1500 Portable DVD Player Logo
132 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
