Having trouble removing the brush unit from the vacuum, so I can check for blockage
Here is the manual with instructions
http://www.eureka.com/FileLibrary/d944cbc8479a49aeafd4f964eb4842df/77297.pdf
SOURCE: Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
SOURCE: brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
SOURCE: Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
SOURCE: In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
