Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
I wanted to know what is the maximum RAM supported by the Intel 845 G/GL chipset series ASUS Motherboard?
  • jjayaraman3 Jan 18, 2009
    Thanks a lot.......
    Problem Solver:
  • 11 Answers
It's 2Gb.
Posted on Jan 14, 2009
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
I lost my asus motherboard driver CD its a asus 845 series motherboard...i need the drivers...can any one hlp?? plx...
Here is link to downloads. Make sure you find exact motherboard model and select the apropriate operating system to download drivers for.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Good Luck.
Nov 24, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Maximum ram supported by 845 glx motherboard
Hello
Can't find any motherboard with that name.
Intel 845GL chipset supports max 2GB of memory.
If you are running windows, you can check more details with
a program called SIW.
It's free and downloadable from http://www.gtopala.com/siw-download.html
Download and run it. It will show you for example the maximum amount of memory your motherboard can handle.
Best regards,
Zizzler
Apr 23, 2009 | Computers & Internet
Ram supported
Go to the ASUS website and download a manual for the mother board. It will have that information  within it.
Jan 08, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Want to replace noisy fan for ASUS Intel 845 Chipset P4B Motherbo
This should give you time to find a new fan
Remove paper center from fan and put a small drop (I mean small) of light machine oil on the bearing then replace paper center.
This should get you out of trouble for a few months at least.
I have done this with at least 8 fans in the past some never needed a new fan
Dec 18, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Asus intel 845 motherboard driver
Go to this link and you can choose your Motherboard model and Download Drivers ;- http://www.intel.com/support/chipsets/sb/CS-009236.htm
Or u can try This link :-
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=757&lang=eng
Nov 27, 2008 | ASUS Pentium 4 , Pentium 4, Pentium D,...
RAM SUPPORT
it depend on motherboard model not the chipset
Sep 02, 2008 | Intel Motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
