Question about HP Pavilion dv4000 Notebook
Menu bar moves up off screen
When I am online, the menu bar is off the screen. I can get it down by moving cursor to the very top of the screen. When I move the cursor, the menu bar goes back up out of sight. How do I get it back down permanently?
    President:
  • 2,559 Answers
Just hit F11 to take it out of full screen mode.
Please rate this solution.
Posted on Jan 14, 2009
    Problem Solver:
  • 11 Answers
In Internet Explorer click Tools, your Full Screen entry probably has a checkmark next to it, click it to remove it and your menu bar will not autohide.
Tool bar moved t right and is large
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?)
Make sure "Lock the Task bar" is not checked
Click on the border of the task bar
drag directly from where you clicked to the bottom
Adjust height accordingly
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
Tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
Remove the drop down icon bar on sony vaio
Usually, with a dropdown toolbar, you can put the cursor all the way to the top of the screen and with the toolbar visible, right click on it to activate a control menu from which you can stop it from dropping down, unlock it and move it to either sidr, or even turn it off altogether.
If this doesn't work, try entering yout laptop model name in Google search followed by "disable dropdown toolbar" for blogs and forums for your laptop model that may have a specific command or trick for your machine.
Good Luck
Jul 27, 2010 | Sony VAIO VGN-CS260J/P Laptop
How do i get my start button on the left corner of my screen? it is at the top right now.
The Start Button is on one end of the "Taskbar"
Use your mouse to move the cursor anywhere on the task bar, click-and-hold, and drag the taskbar back down to the bottom of the screen.
If it won't move (you try to drag it but it's not going anywhere) then right-click on the task bar and un-check the menu item "Lock the Taskbar" then try again.
If this helps, hit the "thumbs-up" for me.
If not, use "add comment" to ask any questions you might have, then check back for answer from me or another FixYa expert!
Jun 18, 2010 | Computers & Internet
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
How do you navigate the main screen
Maybe I am not understanding the question, but you normally would use one of the remotes, make sure the receiver bar is either at the top of bottom of the screen and use the remote pointed at the screen to move the cursor around, click on the desired object using the A button on the front of the remote.
Remote has to be pointed at the screen for the cursor to move around and any movement you make will move the cursor.
Sep 08, 2009 | Nintendo Wii Console
The start menu and task bar appear to be off the screen on my desktop and auto die mode is not on:(
Check to see if AUTO HIDE is not enabled in taskbar settings, move your mouse cursor to the bottom of the screen if enabled the Startmenu and taskbar will re-appear, if not then it was possibly resized accidently, move your cursor to the bottom again if it turns into two arrows pointing up and down then click and hold and drag up and it should be revealed again.
Aug 01, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv4000 Notebook Logo
193 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
