Question about Philips 50P8341 50" Rear Projection Television
Tv won't recieve a remote
The remote doesn't work at all. I have also tried programing universal remotes and the Tv doesn't pick them up. When I try and change the channels on the buttons on the tv it changes the inputs and not the channels. What can I do to fix it? Thanks
    Scholar:
  • 56 Answers
Greetings!
Chances are that the infra-red receiver in the set has gone bad, since you have tried two different remotes. Having said that, it is always possible that the universal remote doesn't have the correct code in it to operate the set. You can always take the original remote to a shop and have them see if it is puting out infra-red. Your local Radio Shack might even have an I.R. sensor to try it on.
If the I.R. receiver is bad I can't give you an easy fix. Though not difficult to replace, the original part (932215244687) has been discontinued. Your local repair shop probably has one laying around that would work, but may not be eager to sell it to a do-it-yourselfer.
Hope this helps,
Rob
Posted on Jan 15, 2009
  • wing_guy_196 Jan 15, 2009
    Sorry, I got interupted and forgot this part. Since the channel buttons on the set are changing the inputs there is a very good chance that there are no channels programed into the sets memory. The front panel of that set has menu controls. Get into the auto-program section of the set up menu and auto-program the set. This should take care of that problem and allow you to change channels on the set itself.
I have a duraband ht395 reciever and need the universal onn remote model ona12av058 code.. All the ones in the manual do not work? Anyone know this?
[PDF]Instructions - ONN Universal Remote Support
myonnremote.com/.../ONB13AV004%20Manual%20Version01.pdf
Mar 28, 2014 - will retain the codes you have programmed for up .... TV/DVD Combo, you might need to set up one ... Point the remote at the audio receiver,.
Faq - ONN Universal Remote Support
myonnremote.com/onn-faq.asp
How do I manually enter codes for my ONN Universal Remote? ... (You haveapproximately two seconds after the device shuts off or begins playing to lock-in the code.) ... so if you need to start the search again, it will pick up where it last left off.Missing: duraband ‎ht395 ‎reciever
RC: Durabrand codes one for all (Page 1 of 2) - Remote Central
https://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?...
May 4, 2006 - 15 posts - ‎9 authors
Jan 25, 2016 | Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Remote doesn't work
did you ask the company where you bought it ,why it was refurbished and what the problem was, try a universal remote, you might have to program in the code from the book you recieve when buying it, try all the codes for your make and model or look on the internet for a service depot and ask if they can get you a remote for your model t.v.
Oct 02, 2012 | Toshiba 57LX177 Refurbished REGZA 57-Inch...
My onn universal remote codes doesn't not work on
Common problem with universal remotes, you can try programming the remote with a slightly different model or brand and see if it does better. Mostly, just learn how it works and deal with it; or try out a different remote. My TV remote and DVD player remotes could both act as universal remotes, but the DVD was much better at it, so we used that one.
Apr 02, 2012 | Televison & Video
I bought new universal remout control, we have tried to program this and it doesn't work. The frist problem is that it does not trun Off/ON, unable to change the channels (does not respond to any...
Return the tv universal remote where u bought it,u only used a universal remote when u must have too,because universal remotes are very strangely and react differencely each models of tvs u tries to programming it codes to it CPU chip.Norcent tvs are recent tvs in the market,have many spare original remote.Try website like Remotes.com to buy the tv original remote.
Jun 18, 2011 | Norcent Technologies LT-2723 Television
Universal Remote
are you programming the remotes with the codes for the TV manufacturer, as most Universals have to be programmed to the manufacturers remote codes to function, or Most if not all universals have a scan for the code function, refer to the manuals did theTV originally come with a remote, I am assuming so, if it didn't the TV may not have an IR reciever for the remote to work.
If this helps, please give a fixya rating, every one helps
May 27, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
TROUBLE PROGRAMING
I have a jumbo universa remote....can you tell me how to programme a viewsat extreme (fta)
Feb 08, 2008 | Philips Magnavox Learning Universal Remote
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Philips 50P8341 50" Rear Projection Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
