Question about Philips 50P8341 50" Rear Projection Television
TV does not recieve a remote
It just stopped working I can't change the channels or volume unless I press the buttons on the tv. When I hit the channel buttons it changes the input and not the channel. Please help. Thanks
Hey, Have you tried to power cycle your remote? That may work, do the TV too. I'll give ya the steps, just follow them and you should be ok. I'll throw in a factory reset as well, but if you're not using a cable box you will have to run another auto scan. anyways start off by unplugging the TV and removing the batteries from the remote control. Let them both sit, you don't have to let the remote sit really, but I do for good measure. You have to let the TV sit for a minimum of 5 minutes. at the end of 5 minutes, you have to find the physical power button on the TV, this means NOT on the remote, but on the TV itself, you have to find this power button, and you have to hold it down for 1 solid minute. Again, any time you can do something extra for good measure, it can't hurt, so if you want to leave it unplugged for 10 minutes and hold the button for 2, go for it, it may help. After you're done with that, power cycle the remote control. Being that your remote seems to be haywire, go ahead and press every single button, this means channel up and down, even if they're on the same button, every one from the top to the bottom, 5 times with no batteries in it. Then hold down the power button on the remote for 30 seconds. Then replace the batteries, preferrably with new ones. This completes the power cycles for both the Remote control and the TV. Now, before plugging the TV back in, we have to do the factory reset. Again, hold the power button on the actual TV, and then, while holding down the power button, plug in the power cord, wait for a couple of seconds, and then release the power button. Wait for a moment, and then turn the TV on. This completes the factory reset.
The reason for all of this, is, power cycle the remote to drain it's capacitors and reset it, power cycle the TV incase the Remote sensor is affected by a static electricity build up. Factory reset incase any settings may have caused this. Hope this helps.
Posted on Feb 01, 2009
  • Cynthia Phillips
    Cynthia Phillips Jan 19, 2016
    TV was responding to remotes fine, then after turning off and back on a little later does not respond to ANY of my remotes.
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Apr 07, 2009 | Samsung TV Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Remote problems and now FPA locked
In the worse case:
It is very possible that the remote recieve on the set has gone defective. It is also possible that there is a fault with the processor in the set, and the remote signals are not being responded to.
As for your universal remote, I don't trust them.
Did you try changing the batteries in the remote? Make sure the new ones are actualy in good condition.
Jerry G.
Jan 01, 2008 | RCA 32V420T 32" TV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Philips 50P8341 50" Rear Projection Television Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
