Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Damaged connector The pins on the slot where the charging cord plugs in are damaged. The phone will no longer connect to the charger. Can this be replaced? If so where would I get the part and the special screwdriver needed to remove the back of the phone?
  • 32 Answers
I went to Ebay and purchased an eternal battery charger for mine because it done the same thing as yours. Of course AT&T told me there was no such thing as an external charger and that they couldnt fix my phone. So I bought a new phone on the spot. Later I checked Ebay just to see if there was an external charger and I found one, bought it and it works great. I use the K1 as a backup phone now since I purchased a new phone.
Posted on Mar 26, 2010
  • 28 Answers
The K1 is not an easy one to take apart compared to others. I would not recommend it. Plus once it is taken apart you lose the seal. I rarely charge my K1 using my phone. I purchased a unit for under $10 to charge my batteries on. I like to have an extra battery for my cell so I am never without service while it charges.
It will cost you more to get the piece replaced on your K1 than it would to get a seperate charger for a battery. If you need help let me know. I will help you locate a charger if needed.
Posted on Jan 14, 2009
Battery problem
follow this test and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Nov 06, 2013 | LG Cell Phones
Iphone wont charge
follow this steps and fix it. God bless you
Jul 31, 2013 | Apple iPhone 3G
Samsung gt 55830 is not charging the battreies
follow the instruction and fix it. God bless you
Jul 27, 2013 | Samsung Cell Phones
Telefunken mr701 diagram
Jul 11, 2013 | Cell Phones
Turn off audible alarm when changing towers
God bless you
Jun 01, 2013 | HTC Cell Phones
When I plug in any charger or a USB cable nothing happens. Sometimes if I move the charger about it charges for a bit but usually nothing happens
if you can,open ytour unit and check the slot where your charger connects.Get rid to the soldered part of the said slot and there is detached foot of the connector,re solder it. Or,the slot is already damaged thats why when you move there is a response sometime.
Nov 05, 2009 | Sony Ericsson S500i Phone
Charger is no longer working
Oh, believe it or not. My computer use to do the same thing all the time. Just take the prongs on the plugin and bend them outwards slowly. This will make a tighter fit in the outlet.
Jun 11, 2009 | Acer Aspire 7720-4428 Notebook PC
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
