Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Motor will not turn over all the time.
It's a coleman black max compressor 1hp,magnetek motor.
  • palmerbil593 Jan 27, 2009
    when it is cold the motor comes on but will not start all the way and kicks the reset button
  • 26 Answers
Is it new or used, does it have oil??hydraulic lock up??compressor dump valve bad,dirty
Posted on Jan 14, 2009
I am wanting to know what this one is worth. "27 gal, 5 HP, 115 volts oil free operation. Coleman power mate black max air compressor?
One sold on ebay for $125.00. It is made by sanborn. Sell locally
freight charge will make to expensive
Apr 19, 2017 | Coleman Air Tools & Compressors
Electric Motor running slow
Century / Magnetek motors are used on many compressors but usually is an upgrade to have the option to easily switch from 110 to 220. Dewalt, Rol Air, Jenny, Emglo and others are considered high end compressors and come with switch for selecting voltage. One still must change the cord if selecting 220v setting. One thing in common is that 115v motors are never more than 2-3 HP because the amp draw for anything over 2hp is likely higher than 20 amps and would trip most common outlet breakers. You noted that your motor sticker lists 6.5 hp at 15 amp 220v so it could not work with 110v because it would draw over 30 amps and just not be practical. Magnetek motors are very good quality and most always state on sticker 110/220v and show wiring diagram for proper connection. Your compressor was most likely built to be stationary and be hardwired into an outlet/switchbox with heavy duty wiring or special cord to run such a high hp motor. You made a great buy however, because the motor alone lists for several hundered dollars alone. You could replace the motor with a 110v but you would loose the fast performance / recovery of that 6.5 hp motor. Like replacing a v8 engine with a 4 cyl. but expect to pull same load, not likely. Good luck with your purchase, and post again if you have other question.
Jul 11, 2010 | Coleman Air Tools & Compressors
I have a Sanborn Black Max 22 gal. compressor Mod#B109BLR300-22SWC. The motor is a Magnetic/Century 3 H.P. 115v Model 8-165730-20 Ser# BF-532 15A-7.5 RPM 3450. It is missing the run and start capacitors....
Sanborn/Coleman was bought out by MAT Solutions. A website I found lists Sanborn/Coleman compressors and parts but it does not show your model number. It does say, however, to email them with your model number and they will be able to find your parts for you. I have included the link for you here: http://www.mastertoolrepair.com/colemansanborn-portable-parts-freedirect-drive-electric-c-271_35_172_178.html
Sep 10, 2009 | Air Tools & Compressors
Coleman black max air compressor
go to the coleman website, or to another site which shows how to identify the compressor by looks.
Aug 05, 2009 | Coleman Powermate 60 Gallon Air Compressor
Compressor will not build pressure
It sounds like it is not getting enough electricity.
Try plugging in to an outlet on its own circuit without an extension cord. make sure the circuit is rated for your air compressor. If it is on a circuit with other appliances, refrigerator, lights, ect. try shutting them all off before turning on the air compressor.
Good luck
Aug 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
May 16, 2009 | Coleman Air Tools & Compressors
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
253 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
