Question about Sony (CRX230ED) CD-RW Burner
Sony CRX230ED plug n play but no drivers
I've uninstalled the drive then reinstalled it but after I use the adhardware wizard it says that a problem occured and that i may not be able to use the device which is true. it just wont work. in the device management screen it shows that the drive is plugged in but has yellow circle with a black exclamation mark in it. i've downloaded drivers but each time i go to install them one says sony cd extreme is not installed properly and the other says no matched drives detected. please, what can i do???
  • Anonymous May 06, 2009
    I have exactly the same problem.
2 Suggested Answers
Damilare
  • 358 Answers
SOURCE: cd-rw 230ED, not working
Try this Solution : Download a firmware flashing tool, and an Updated Binary File for the Drive,
Then Run the Firmware Flashing tool, and Locate where the binary file you downloaded is, then click on Start.
The link for the Firmware Flahing tool and the Binary File for the drive is :
http://www.allfirmware.narod.ru/OS.htm
Its a russian site, but just scroll down and locate the model number of your Sony CD-RW, You'll see both the Firmware flashing tool as well as the Updated binary file for it just beside it.
Hope this helps.
Posted on Jul 12, 2009
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
Need a driver for SONY CDRW/DVD CRX835E
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Aug 07, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Hp dvd rw ds-8a1p drive driver please
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
hope this helps dont forget to vote
Mar 12, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Seagate 40gb hdd drever
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a disc the drivers could be on it
hope this helps
Feb 15, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Need to update my drivers for sony cd-rw crx230ed my cd rom wont even read
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw burner then plug them back in this should activate the found new hardware wizard or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 28, 2011 | Sony (CRX230ED) CD-RW Burner
Drive isn't turning on, not getting power
make sure that the cdrwdvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrwdvd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
hope this helps
Dec 28, 2010 | Sony CRX330E CDRWDVDROM Combo Drive
Hello, My problem is that the drive does not eject smoothly. It has to be given a gentle push to close and has to be pulled to open. What is the solution for this problem? The drive burns and play disc...
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 23, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
Cd-rw 230ED, not working
Hope this helps.
Jul 12, 2009 | Sony (CRX230ED) CD-RW Burner
DVD DRIVE NOT BEING RECONISED
This is a solution for error code 41 but it may assist you with your problem.
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Apr 07, 2008 | Computers & Internet
Sony (CRX230ED) CD-RW Burner Logo
683 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
