Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Am I supposed to just put the memory stick in the usb port in the front of my cpu? How long does it take before it's done. This is the first time I've ever purchased this.
    Problem Solver:
  • 9 Answers
Most of these portable memory sticks are all plug and play. This simply means they are ready to be used whenever and wherever. Just plug in the drive to your USB port and drag files into the listed hard drive. Just remember, do not pull this stick out of the USB port without pressing "safely remove hardware" on your start bar. Failure to do this can result in frying your flash memory. Best of luck!
Posted on Jan 14, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I want to update my bios
Oh?
Kvpsy,
The information tells me;
1) Operating System: Windows XP Pro with Service Pack 3 (SP/3)
2) Processor: (CPU) Intel Pentium 4, 3.06GHz,
(Or also stated as 3.066MegaHertz) {3.066MHz}
Uses an LGA775 processor socket.
Front Side Bus = 133MHz.
(Intel processors are 'Quad Pumped'. 133MHz is the Internal Clock. 533MHz is the External Clock.
4 x 133 = 532. Number is rounded up to 533)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
Scroll down.
Prescott Core, 90nm architecture.
Pentium 4 HT model 524.
sSpec number on top of the Processor, (Heatsink removed), is either
SL8ZZ, or SL9CA
3) Motherboard manufacturer name, and model number:
Intel D101GGC
Version AAD357
3) Motherboard chipset:
ATI Radeon Xpress RC410 = Northbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
IXP450/SB450 = Southbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Southbridges_2
4) GPU: (Graphics Processing Unit, or slang = graphics chipset)
Built into the motherboard chipset; ATI Radeon 200 series with 256MB's of graphics ram memory.
(? Really? I would think more like 64MB for Integrated Graphics.
Are you running a graphics card, in the PCI-Express slot on the motherboard? Got one in one of the PCI slots?)
5) Ram Memory:
2 Ram memory slots
DDR Sdram at 400MegaHertz. Also known as PC3200.
Maximum TOTAL amount is 2048MB. (2GB)
Amount of ram memory that installed now, 1024MegaByte. (Or also stated as 1GigaByte)
960MB is what shows.
(64MB's of ram memory is being borrowed)
32MB DRAM modules. Memory module/s ('Stick') use 5 Volts (DC)
60nanosecond to 70ns, Cas Latency of 3. (CL3)
6) Harddrive:
IDE
Western Digital WD1600AABS
150GB
7) Optical Drive:
IDE (EIDE really)
Manufacturer = LG Electronics
Model number = GH22NP21
DVD burner drive
8) C-Media CMI8738 audio (Sound) chipset
9) RTL 8139 Ethernet chipset
10) Basic Input/Output System (BIOS) manufacturer = Phoenix/Award.
Version = 6.00PG
Release date = 04/20/2006
BIOS String ID = GC11010N.86A.0311.2006.0420.1525
NOW, the message you received is -
SUGGESTION: Are you looking for a BIOS upgrade?
System BIOS is more than 2 years old. (WELL NO KIDDING!!)
Video BIOS is more than 2 years old. (Yeah? AND?)
A) AS SOON as you purchase a motherboard, the BIOS program is ALREADY out of date.
BIOS upgrades are made about 2 weeks, after the motherboard hits the market.
TWO WEEKS!!
What does this mean?
It means LEAVE IT ALONE.
If everything is working OK, DO NOT perform a BIOS upgrade.
Why?
Because for;
1) IF, the power goes out to your house/business, when you are downloading, the BIOS upgrade WILL NOT be completed.
What does that mean?
Take the motherboard out of your computer, and use it for a Frisbee.
2) IF, the BIOS upgrade is too new, and/or NOT compatible, AND if you do not save the old BIOS version, take the motherboard out of your computer, and use it for a Frisbee.
IS there a cure for ruining the BIOS program in your BIOS chipset, on your motherboard, and downloading, and installing the original one?
SURE!
Take it to a PRO, who will download the ORIGINAL BIOS, to a Floppy Disk, (Or disks), using an internal Floppy Disk drive, connected with a floppy disk ribbon cable, to your floppy drive connection on your motherboard, and put it on your motherboard.
MAYBE.
(Not shouting. Illustrating a point)
OR, if the BIOS chipset is removable, (It is soldered on the motherboard), perhaps another BIOS chipset is available, for a PRO to solder the good one back on the motherboard.
You HAVE been advised.
BIOS upgrade download page,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021749.htm
Motherboard Manual,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Regards,
joecoolvette
Jun 16, 2012 | Intel Computers & Internet
Somehow my brother put memory sticks in upside down< by much force I am sure. Now, Asus A7V8X-LA will no longer recognize any memory sticks. Just keeps giving memory beep sequence. Bared it to mobo,...
The USB port has 4 pins, 2 are power ans the other 2 is for data. Your motherboard may be damaged with some of the power pin shorting out components on the motherboard.
Jul 07, 2011 | Computers & Internet
I am running on Windows Vista. I have 2 8GB Lexar twistturn USB sticks and it keeps popping up with "device unknown, no driver for device". Have you got any suggestions to fix this??
are you already use the usb port at the back cpu? sometimes, usb port front have the problem.
8GB usb stick will need time for detect it.
May 09, 2011 | Computers & Internet
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
How would you save a story on micro word with a memory stick
Hi Friend,
Please follow the gevin instructions-
1-Insurt the memory stick in USB port of the CPU (USB port available in front and backside of the system)
Note-mainly system detect memort stick automaticaly,some time not detect at that condition go to tme my computer maange option(after right click of the my computer you will be able to see the manage option and go to the device maange and update the USB driver)
2- Copy the data (micro word)
3-Past the data into pen drive (memory stick)
4-disconnect the memory stick
Thanks,
Mar 10, 2010 | Computers & Internet
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Card reader not working
Try putting your memory stick on a usb port on the back of the cpu. It may work. Usb ports on the front of the cpu and card reader may not work with all memory sticks
Dec 17, 2008 | E-Machines eMachines Desktop PC
Motherboard for a e-machine t6420
CPU: AMD Athlon™ 64 3400+ Processor (with AMD 64 technology)
(2.20GHz, 1600MHz system bus, 512KB L2 cache) Operating System: Genuine Microsoft® Windows® XP Media Center Edition 2005
Chipset: NVIDIA® nForce™® 410 Memory: 1GB DDR (2 × 512MB), 400MHz dual channel
Expandable to 4GB Hard Drive: 200GB HDD (7200rpm, 2MB cache) Optical Drive: 16x DVD±RW multiformat double layer drive Media Reader: 8-in-1 digital media manager (Secure Digital™ (SD), smart media, micro drive, memory stick, memory stick PRO, compact flash, multimedia card, USB 2.0) Video: NVIDIA® GeForce® 6100 GPU
up to 128MB of shared video memory
PCI-Express® (PCI-E x16) slot available Sound: 6-channel (5.1) high definition audio Network: 10/100Mbps integrated Ethernet LAN (RJ-45 port) Modem: 56K ITU V.92-ready fax/modem (RJ-11 port) Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 5 USB 2.0 ports (4 in back, 1 in media reader), 1 VGA external connector, 1 serial port, 1 parallel port, 2 PS/2 ports (keyboard and mouse), 5 audio ports (2 in front, 3 in back) Dimensions: 14.25"H x 7.25"W x 16"D Weight: 22.5lbs
LInk to spec page : http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
Sep 29, 2008 | Brother CS-8150 Computerized Sewing...
Memory Stick
dcp 130c cant transfer plain data. Its a pic bridge (digital camera standard) connection only.
You have to use your PC USB.
Jan 10, 2008 | Brother DCP 130C All-In-One InkJet Printer
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
50 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
