Question about Kenmore 24 in. 16032 Built-in Dishwasher
Need to remove wash module
A part from a pan fell into the wash module. How do I remove the lower spray arm, etc. in order to remove the part? --- Thanks!
  • Anonymous Mar 12, 2014
    how do I remove the lower spray arm
How do i clean the filter screen under the spray arm of a kenmore ultra dishwasher
Posted on Oct 14, 2008
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Posted on Aug 02, 2007
How do I remove lower spray arm
Pull out the lower wash rack. Using a flat-bladed screwdriver, CAREFULLY pry the 2 tabs at the bottom of the washarm so it can move up and over the "hold-down plate" Be careful! Those tabs have a tendency to break off, especially the older the dishwasher is. You may be forced to buy a new wash arm.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 25, 2015 | GE Dishwashers
Whirlpool dishwasher DU1145XTPQA. I removed the lower arm etc and cleaned debris from my chopper/pump area. went through steps in reverse to reassemble it all BUT when I put the lower spray arm back on and...
I did the same exact thing, and ended up with the same result, A very wobbly lower spray arm. Despite it wobbling and hitting the feeder tube to the upper spray arm, it works.... somehow....
Nov 14, 2010 | Dishwashers
Kenmore dishwasher #665 only sprays water for a sevcond. will run cycles just won't spray more than a second
This is a sign of food particulate that is blocking the impeller inlet under the lower wash arm. Remove the lower wash arm noting EXACTLY how it comes off as you remove it. Then clean out the particulate. You may have to unscrew the lower wash arm tower also to get to the particulate.
Once yopu get it cleaned out it should work just fine. This does not happen often but..it does happen. It should not repeat anytime soon.
If you need exact instructions with part details I will need your full model number.
I think this is your dishwasher:
http://c.searspartsdirect.com/lis_png/PLDM/10054505-00004.png (Enlarge)
You may have to remove Item 14 (ONLY) to clean off the screen Item 1
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Kenmore Dishwashers
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Oct 25, 2009 | Kenmore Dishwashers
Kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
May 21, 2009 | Dishwashers
I have a whirpool Quiet Partner III, and the top layer of glasses is not getting clean. I had a technichian out some time ago, and the problrem was caused by food debris trppaed in the filter in the wash...
CHECK THE SPRAY ARM HOLES,ARE THEY CLOGGED ??IF THERE NOT YOU MAY NEED THE PUMP REPLACED (NO PRESSURE).........BY THE WAY THE POWER DRIVE UNIT IS NOW REFERED TO AS A > MOTOR/PUMP WHICH IS NOT INCLUDING THE PUMP.IT'S THERE WAY OF ADDING CONFUSION WHEN WE ORDER PARTS. 1ST LOOK FOR CLOGGED SPRAY ARMS. LEAVE A RATING !!
Jun 08, 2008 | Whirlpool Dishwashers
a screw fell into the wash moduel. How do i remove the lower spray arm, ect Thank's
Feb 08, 2008 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
510 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
