Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
Verbatim when i plug it with my computer it shows "insert a disk in drive j
  • 4 Answers
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Posted on Mar 04, 2009
How do I use a verbatim MF2HD microdisk
A floppy!?? Really!? I think you might have to go back in time. LOL! Well, if you have an adapter or a port for it, just insert the disk and that's it.
To format the disk just insert disk, click 'start' and then 'my computer', right click usb drive and select 'format', select proper system file and press 'enter'.
Mar 18, 2014 | Verbatim Computers & Internet
My notebook is not detecting this desktop drive (3.5'' 1 TB external desktop hard drive - verbatim). My other 500 GB external hard drives are properly detected.
Go to Control Panel - Administrative Tools - Computer Management Then go into Disk Management. Hopefully you will see a drive with a capacity of about 480 GB (plus or minus), that's your disk.
Right click on it and select change drive letter and change the drive letter to something that isn't in use.
If that doesn't work or it doesn't show up, go into the Device Manager from the Computer Management screen and see if there is anything under disk drives with a yellow or red symbol next to it. If so, right click it, select uninstall, then unplug the disk drive and plug it back in.
Feb 27, 2011 | Verbatim 1TB SMARTDISK HD USB-FWIRE COMBO...
Please insert disk
Insert the disc that came with it ( if no disc came with it then it should not need one.) If it still insists it needs a disc go the verbatim website and go to the drivers/software/downloads page, and select the model of the pendrive and download the appropriate drivers ( your operating system etc XP or windows 7)
Plug it into the usb port and go to 'my computer' there you will see the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Jan 06, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
When i plug my verbatim hardrive in all i get is " please insert disk into drive f" and will not let me open the drive.
Windows is unable to read a valid "Table-Of-Contents" from the disk-drive. So, Windows is "guessing" that writing an "empty" Table-Of-Contents onto the disk-drive is the best action to take, but it's asking your permission, before proceeding. If you have existing files on the device, say 'no'. If you have NO files, or you are willing to "forfeit" ALL the files currently on the disk-drive, say 'yes'.
If you say 'yes', and Windows fails to write the new Table-Of-Contents, then there's something physically wrong with the disk-drive. Check the warranty-status of the device -- if the warranty sitll is valid, Verbatim will replace the device, at no cost to you.
Oct 30, 2010 | Verbatim SmartDisk Firelite Portable USB...
When i plug my Verbatim hard drive into my PC it is not showing up anywhere. The light on the unit is iluminated, yet the unit is not showing as a "found" piece of hardware, nor does it appear in "My...
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 22, 2010 | Verbatim (96532) 50 GB USB 20 Hard Drive
I had verbatim 8gb jet flash.when i connect it pc it shows "please insert removable disk" why
My gues is the flash drive is not formatted to FAT32, or the USB port drivers are not installed. What operating system are you running?
Apr 21, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
2gb jump drive not working
There are two major possibilities:
1: There is hardware or software problem with your computer's USB ports. To test this, plug the drive into a different computer if you can, and try having it plugged into your current one while you turn the computer on.
2: The issue is with the Jump Drive itself. If the drive fails to show up when plugged into a different computer this is the likely problem. The data CAN be recovered, but if it won't show up on any computer, the only real way to do so would be to pay a Hard Drive recovery shop.
Sep 21, 2009 | Verbatim VER95327 USB Hard Drive
Portable hard drive won't show on desktop
it could be defective cause you might have taken the stick off while it was loading or if not you can plug it again and try opening it through My computer/ Removable disk:
Jun 19, 2008 | Verbatim VER95327 USB Hard Drive
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Verbatim Thumb Drive problem
You may need to log on to the computer with administrative privileges. Ask your friend to log you into the Administrators account, then insert the drive.
Sep 02, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
205 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
