Upload service manual sony kp-fs43m31/m61/m90/m91, fs53m31/m61/m91
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Hi Benimur,
I paid and downloaded the service manual (21 MB) for the projection TV Sony kp-fs43m31/m61/m90/m91, fs53m31/m61/m91
I didn't fix it yet but ready to upload it somewhere like :http://www.eserviceinfo.com.
Do you have a better one to recommend?
Also, on this TV I tested the board at the very end of the tube and seems OK .There is another card fixed to the tube ( the velosity modulation card) whoseems to have different characteristics (maybe bad ones) than the other (Icompare with the one on the green tube). Do you think that this card might beresponsible for the light convergence of the red color?
It started with a diagnosis of High voltage or 5volts problem seen on the standbye light after the red bulb was over powered and the TV turned offautomatically.
I fix the overpowering by decreasing the focus for the redtube. I get a reasonable good picture but we can see that something is wrong ona picture with a lot of red.
cheers
  • 2 more comments
  • wings_it
    wings_it Jan 14, 2009
    Ready :
    http://wings_it.orbitfiles.com
    It will go file qube too soon
  • wings_it
    wings_it Jan 15, 2009
    sorry my bad :
    http://www.orbitfiles.com/search?searchf...
    it took me a bit to learn how to use orbit...
  • wings_it
    You're right with the TDA 6120Q unless you tried with an oscilloscope 50mhz. I tried with a 10mhz to measure the pin Vout (12) and compared with the signal on the green CR board, they were similar.
    So I went to The VM board. This one has several transistors heat sinked too, I was able to test them on board and compared with the green one. there is difference.
    What do you think about the VM board (page 97) might be the cause?
    How to be sure that is not a convergence problem?
  • wings_it
    OK thanks for your Expertise it's really a great help, I needed it, I 'll check that later when fixed I let you know.
    thanks
    Brigadier General:
  • 6,966 Answers
Hi again JP,
There are a number of free online file storage. An example is File Qube or Orbit Files.
Soon as you post the link to the file and I could download, will let you know my thoughts.
Cheers.
Posted on Jan 14, 2009
  • 1 more comment
  • Louie  Role
    Louie Role Jan 14, 2009
    Its asking for a password
  • Louie  Role
    Louie Role Jan 15, 2009
    Initially, let's concentrate on the CR board, right at the rear end of the red tube. If a replacement board is available, that would be the quickest approach. If not readily available or if you prefer component level, then you need to check the components of this board specifically, the transistors, diodes, capacitors and resistors. Two components that would not be possible to check completely are IC9101 (TDA6120Q) and Q9102 (2SK2036) other than obvious shorts or burned chip. Offhand I would suspect the IC more and/or this 2SK rather than any of the other components. The easiest would be simply to replace (good or bad). Though it is only fair to mention that in some instances, it could be just an open resistor such as the R9120.
  • Louie  Role
    Appreciate the update.
    • On the VM board - for the moment, I doubt. The difference could be attributed to the colors of the signal source. Perhaps you could try again with with a black & white video signal (an NTSC VCR or DVD);
    • convergence - this too I doubt. If it were a convergence issue, the red would not be overpowering, the color strength would be the same except that they videos would be 3 (for each color) and would not merge;
    • CR board - hoping to check further this board, have you also checked out of circuit (at least one leg) R9104 and/or measured voltage at pin 10 of the red tube?
    • when you checked pin 12 VOut and compared with the green, was the amplitude also compared?
I was Given a sony tv projection model no kp-44px3u and require a user manual guie can you help
SONY CRT Projection television.
This looks like an 'Asia' model probably used in New Zealand.
You can get a manual by going to;
http://www.sony-asia.com/support/product/kp-44px3u/manual
Then click on the Operating Instructions link.
» Operating Instructions
File Size: 1.43 MB
Part Number: 4-102-591-41(1)
Date: 31 Mar 2004
English
Apr 15, 2011 | Televison & Video
Tip
Sony KP-61XBR48 Service Manual Download
Download Sony KP-61XBR48 Service Manual
Would you like to download a free Sony KP-61XBR48 Service Manual?
Have you lost your Sony KP-61XBR48 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-61XBR48 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-61XBR48 Service Manual documentation.
I hope that helps.
___________________________________________
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | Sony KP-61XBR48 61" Rear Projection...
Tip
Sony KP-53XBR45 Service Manual Download
Download Sony KP-53XBR45 Service Manual
Would you like to download a free Sony KP-53XBR45 Service Manual?
Have you lost your Sony KP-53XBR45 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-53XBR45 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-53XBR45 Service Manual documentation.
I hope that helps.
on Jul 04, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 04, 2010 | Sony KP-53XBR45 53" Rear Projection...
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Dec 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Pip
Please download user manual of Sony KP-53XBR45 and get reply of all your questions about tv.
Regards,
Sep 19, 2008 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
