Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Apex model#GB4308 I geta 6 inch wide line in the middle of tv at intermittent times sometimes all day I will get it,other only at night etc,,I can afford a new one I am disabled with low income Please Help!
  • pop57 Nov 20, 2007
    I have the same problem with the Horizontal.
  • 934 Answers
If you mean a horizontal line going left to right across the center of the screen and it's intermittent then a tech should be able to fix that one on a service call fairly easy... The vertical IC in that unit, IC N301, is a TDA8351 and it most likely has some poor solder connections due to heat stress - we call ring cracked - thus the problem sometimes corrects itself temporarily. While he's coming out anyway ask him ahead of time to bring the following: Two resistors 1.0 ohm 2 watt and a cap 3300 microferet 25 volts and his DMM & ESR meter. Ask him to ESR test C863 this is a high failure cap and test R370 & R371 in the supply for change in value. Shouldn't be too much to repair - and simply ask ahead of time what they charge for a service call, and if they think they can correct such a problem (ring cracks on the solder connections of your vertical IC) on-site. If you're not too sure where to begin your research for a qualified shop try NESDA at: http://www.nesda.com/locator/state_search.php Good Luck Bill
Posted on Jun 13, 2007
SOURCE:
Samsung Tantus projection TV 40 inches. the problem is that when it has worked for 5 minutes the text and picture is having a trace line that looks like a convergence problem in conventional CRT tv. any...
U have the early warning problems of the convergence problems.Do the manual or auto convergence adjustment until,u can't do it anymore.Replaced all the parts,that make the convergence board to work.
Jun 22, 2010 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 43 inch projection tv
This is not my main field of expertise, in any case here is the link for a solution to same problem and same model. According to expert the problem is related to vertical chip fault.
http://www.fixya.com/support/t142256-apex_gb4308_multi_colored_horizontal_bow
hope it may help you
cheers
Feb 18, 2008 | Apex Digital GB4308 43" Rear Projection...
Auto focus button was pushed a few times and now our Apex TV won't focus at all.
likely a convergence failure. if you push the button over and over, sometimes it will throw the set out so far that it cannot align anymore.. the sensors need to see the lines to do the auto alignment. you probably need new convergence ICs, repair is tricky and requires soldering. estimate = 200-350 $
May 26, 2010 | Apex Digital GB4308 43" Rear Projection...
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
Problem with tv APEX DIGITAL GB4308
it sounds like your lenes need cleaned and alined
Dec 08, 2008 | Apex Digital GB4308 43" Rear Projection...
APex rear projection TV Model GB4308
It sounds like the transformer overloaded and fried should be an easy one!
Oct 20, 2008 | Apex Digital GB4308 43" Rear Projection...
Help with my tv
I don't know what you mean by "good". I've worked on this set several times for different problems. What do you need ?
Dec 02, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 multi colored horizontal bow in middle or screen.
This is not an "STK" problem. Your problem is VERTICAL. You need to check your vertical chip for damage CN301 and check around it for any bad parts or loose connections. I've seen loose connections on the chip itself cause it to self-destruct.
Apr 11, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308
check for cold solder joints @ convergence board, mainly right underneath ic's
Dec 21, 2006 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
81 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
