Question about MPC Computers TransPort GX3 Notebook
NEED TO RESET FINGER PRINT
It will not come on after being charged
    President:
  • 2,559 Answers
If you can start with your password,all you need to do is delete the finger print profile file in your fingerprint program folder and then run the program to register the fingerprint again
Posted on Jan 14, 2009
How can I unlock my toshiba laptop that has the finger lock
You need to perform a factory reset see this page
How To Perform system recovery Windows 7 TOSHIBA FORUMS
in order to remove the finger print software.
Nov 03, 2014 | Computers & Internet
Froze on garmin screen won't give directions
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Jan 04, 2013 | GPS
Finger print scanner won't work and can't remember my password - I can only get in to my 'Guest' account. What should I do?
Download and use password recovery software. Download the bootable dvd image and burn it into DVD or pendrive. boot from it and run the software. you can reset your password.
Jul 01, 2017 | Sony VAIO SR Series Notebook PC...
Camera not focusing properly, blurry result. can you help?
Hi, you have problem in lens Focus maybe the gear focus was stuck up becuase of sand or dust that goes inside of your camera. what you need to do is:
1. try to reset the camera to default setting-maybe you make some wrong setting to your camera-kindly check if the problem still occur.
2. clean the lens glass-maybe there's a moisture or a finger print from the glass of the lens -check
3.if the problem still occur you need to check if your camera are still coverd by the warranty. If yes bring to service center and for sure this will covered by warranty of if they charge you with minimum charges.
good luck and thank you my friend
Jul 21, 2010 | Olympus Camedia D-425 / C-170 Digital...
Error E8 on Canon PIXMA MP 150 printer. It will print on pressing the "diamond" key but needs the same treatment after each print command. What to do?
Hello
Here is something you can try, all credit Ben k:
(1) have your printer power down ie. off, just to make sure pull the plug out and wait 10 seconds.
(2) plug printer back in, now Hold down the Stop/Reset button don't let go.
(2a) push and hold the on/off button
----at this point both fingers are holding down the buttons.----
(3) take your finger of Stop/Reset, pause maybe a second now press stop/reset button once and then press again and hold.
--- both fingers at this point are hold down both buttons----
(4) take your finger off on/off and now finally take your finger off stop reset.
---wait for the printer to go into its service mode ie. wait maybe 30 secs a min whatever till the printer carage has moved back into ints original spot.
---after this has occoured you should be able to press Stop/reset to cycle though the options
each time you press Stop/Reset Alarm and on/off should alternate lighting up. Hope this helps.
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Hope this helps good luck
Dec 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Finger print software causing blue screen of death
drivers for fingerprint software became corrupt. uninstall and reinstall of drivers along with doing a hardware reset (bios/security/fingerprint hardware) did the job.
Nov 04, 2009 | Lenovo ThinkPad X301 Notebook
Error e 27
he method for doing so is worded very badly on alot of sites so I will explain my way.
Feb 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste Ink Absorber full on Pixma MP 150 printer
Before we start what needs to be done is that the two little filters under the printer carts need to be cleaned as well as the two little rubber parts housing the filters; wash these in water (after taking out of the printer) the filters should come up white-ish.
Also make sure that while you have the filters out to clean in and around that area with a cloth / tissues something to absore excess ink. After you clean this however you still need to service resert your printer.
The method for doing so is worded very badly on alot of sites so I will explain my way.
Jun 14, 2008 | Office Equipment & Supplies
Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Jan 22, 2007 | HP iPAQ H5450 Pocket PC
MPC Computers TransPort GX3 Notebook Logo
132 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
Bhagyanath N
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
