Question about Whirlpool LER4634J Electric Dryer
Heating element not getting hot
How do you change heating element
  • 5,911 Answers
If the model number you have this listed under is correct, the heating element on this model is easy to get to. Follow these steps:
First, make sure you have the correct voltage at the wall receptacle and at the terminal block in the back of the dryer of 220-240VAC. If the voltage requirements are not correct, this can cause the heating circuits not to function, but the drum will still rotate. To access the dryer heating circuits, follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltages are still present inside the dryer with the unit turned off.
2. Remove the dryer vent hose from the back of the dryer.
3. Remove the back panel by loosening all screws holding the panel in place.
4. The heater box will be located on the right-hand side (as viewed from the rear). The heating element is housed inside the heater box with the Hi-Limit Thermostat located the closest to the heatet terminal and the Therm Cut-Out (TCO) located at the top end of the heater box.
5. Measure the TCO, first. This is the first likely cause of a no heat problem. A good TCO should read a short (0 ohms). 6. A measurement across the heating element should read about 15 ohms or less if good.
NOTE: Remove the wire leads from any components under test to ensure a proper reading. If any readings are abnormal, replace the component.
Illustrations of your dryer are available at searspartsdirect.com. Just type in your model number and look for item number 6, 15 and 17 under the "Bulkhead" heading. Repairclinic.com and appliancepartspros.com are also excellent sources for finding parts.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 14, 2009
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
The dryer is getting very hot and then the timer appears to be sticking at 20 mins to go. I have changed the thermostats already.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 16, 2015 | Hotpoint Dryers
My Hoover vhv680c tumble dryer is working but does not get hot I have changed the element but still no good
There are other possibilities. Dryers have one or more temperature sensors that will open circuit the heater element if they get too hot. If the sensor goes bad you get no heat. These are usually located near the end of the heater element. Find the wiring diagram and you will see them. With the dryer unplugged you should be able to measure almost no resistance across their terminals. Another possibillity is in the timer. The contacts inside of it could be bad. This is likely if you get heat on some cycles and not others.
Dec 07, 2014 | Hoover Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Element
I do not believe that there is an element in this machine. You get hot water from you tap. There is only a heating element in a dryer. If your not getting any hot water I would suggest that you check your hot water solenoid.I hope this helps you out.
Nov 22, 2008 | Indesit W 123 Front Load Washer
Will run but heat up
When you say that it will run, is the heater element getting hot and is the blower on or off? Those are two distinct and seperate issues that I will need to know in order to assist you...Please get back to me with that information...
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
REPLACE HEATING ELEMENT ARISTON DISHWASHER
My dishwashers heating element seems to have stopped, because there is no hot water!
How do I
a) find the heating element?
b) change the element?
Thanks
Apr 30, 2008 | Dishwashers
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Whirlpool LER4634J Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
