Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Bizhub C351 Magenta Image Unit Problem
Sam88kid, Change the magenta image unit (part no.4047-603)? I've changed the IU itself are you suggesting it has a separate waste part?
  • 2 more comments
  • mcmurphi Jan 14, 2009
    Changed it 3 times and only works for a short duration with new IU.....3-4 thousand prints.
    The tech is supposed to show up today, can I update the firmware myself and how do I check it?  The reason I ask is I'm not sure he will show up as calls are not being returned. (Bought the machine from them W/O service contract and well, they are not to receptive to my needs)
    How do I check the tube from the toner to the IU if it might be plugged, that sounds like this might be my problem here.......
    If my problem was the tube from the toner to the image do I get to that to see if it is plugged?
  • 66 Answers
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
Bizhub C351 Magenta Image Unit Problem - ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Posted on Jan 14, 2009
  • sam88kid Jan 14, 2009
    Sorry...didn't answer the question. No the waste part is part of the IU. Sounds like the Magenta IU is taking in more toner than usual and the waste compartment cannot cope.
    Check the firmware. Might need to update the firmware.
In the magenta image unit Vg and Vdc is very high. I change imaging unit-hv1-hv2 but problem did not solved
If Vg and Vdc are very high and you have confirmed that all contacts with the magenta image unit inside the device are clean and making solid contact with the imaging unit, you may have to replace the High Voltage Power Supply (HVPS) as it is passing too much current to the unit.
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
Lost yellow and magenta in test print
Enter in the service mode and select tes mode select gradation test pattern and make a test for black,cyan,magenta and yellow.If the gradation is not OK you have change the bad imaging unit,or change the developer and drum in the bad image unit + the chip.
Mar 25, 2014 | Konica Minolta Minolta Bizhub C253 Copier
I have konica minolta bc 250 its giving error c2553 pl help me
hello it is a image unit problem.
You got your toner/developer ratio out
Magenta will be low as we know.
Then while still in service mode run TCR supply
Re-check ratio % you should be OK
Change magenta image unit
Feb 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
Error 2652
C2652 Magenta Imaging Unit EEPROM access erro. you need to:
1. check if EErpom of Magenta Unit is not dirty. if it is, clean it.
Else, replace the Unit image.
Aug 08, 2008 | Konica Minolta bizhub C351 All-In-One...
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
547 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
