Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ejecting the water filter
I don't see the eject button as described in the manual.
    President:
  • KitchenAid Master
  • 2,651 Answers
Rigth next to the filter itself "on hte toe grill" should be a spot marked "PUSH"
Posted on Jan 14, 2009
I can't remove the old filter to replace it. You're supposed to push the button in and it would pop out, but it won't go in. 56166501 is model.
If its been some time since you last changed the filter then you may need to pull the filter holder while holding the eject button. Don't twist the cap on the holder, just pull.
If you can't get a grip on it and the eject button still doesn't work then remove the base grille by openeing both doors and pushing the top and pulling the bottom to give you better access to the eject button and filter holder.
Jun 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Apr 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Where is the eject button for a kitchenaid superba water filter?
I went through this same thing! You probably can't find an eject button because there isn't one on the model that you have. It probably isn't turning because it's just stuck and you have to just have confidence that you're not breaking it and force it to the left - all of a sudden, it will "pop" and turn easily.
Here is a great link to show you the different types of Kitchen Aid refrigerator filters - which kind has an eject button and which doesn't:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/149
I also found a great (and short!) video from Kitchen Aid that really helped me see how to do it. Try this one - I thought it was the best:
http://www.kitchenaid.com/content.jsp?sectionId=852
Finally knowing there wasn't an "eject" button saved me many hours of looking, and the tip about using the handles of the plyers worked great.
It is really discouraging to think you can't just screw out a water filter, but it isn't you. The directions are misleading - they don't match what you're seeing, and it doesn't twist out easily - it has to be forced....and THEN it twists out easily.
Hope this helps. It worked for me when I'd completely given up.
Best of luck!
Eileen
Sep 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water filter does not eject when button is depressed.
I just had the same ting happen to me. You need to leave the cover to the water filter (it is the black plastic cover that is part of the grill) is still connected to the filter. After depressing the eject button, this cap helps to pull out the filter. DON'T throw away this very important part, other wise it is impossible to get the filter out. Once you eject the filter, some water will leak from the filter. Just put it in the sink to drain for a while.
Apr 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Location of eject button for water filter
For more information or advice regarding water filters visit www.h2ofiltercentre.com it’s the best place I know to find affordable water filters and advice in the UK.
Call 01273 74 74 77
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Cannot locate water filter eject button
your water filter is located in the kickplate area, you either have to twist it counter clock wise , or rightnext to the filter is a little button says PUSH. it ejects the PUR filter for replacement . ordering instuctions on filter itself
Mar 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water filter
Its on the bottom left of your fridge. 1. Press the eject button to release the filter from the base grille. 2. Pull the filter straight out. 3. Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4. Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. 6. Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Jul 30, 2007 | KitchenAid Superba Architect KSCS25IN Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
173 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
