Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Spark no gas
My gas line is on and i have spark on the surface of my oven but still no gas to ignite
    Scholar:
  • 89 Answers
First off use a BBQ match and try to light one burner manually with the match. if it lights then the next thing to do is physically move the ignighter closer to the burner plate. if not then you should check the gas line as far into the stove as possible. and if you still dont have a flame then its either time (for the tool savey) to tear into it checking all gas lines and valves to see if they are open or you should call the repair man. sorry i couldnt be of more help
good luck
Posted on Jan 14, 2009
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
I have a tappan gas stove. the stove top works but the oven doesn't heat up enough to cook and i can smell gas. I checked the gas line and it is tight with no leaks. i am wondering what could it be and...
You could do the repair yourself. Much more information is needed. Is your oven spark ignition or hot surface ignition ? A valve may be opening only partially. This can happen on a hot surface ignition system when the glow bar is starting to malfunction. Need to know more details to be of real help.
Tom
Aug 10, 2010 | Tappan TGFS26C Gas Kitchen Range
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
How do i light the oven pilot on a ge xl44?
MOST modern appliances that use gas ignition (including dryers) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work and how to access the them on a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
The surface burners use an electrode type igniter for ignition. There is one mounted next to each surface burner assembly. They get their electric source from a spark module. If none of the surface igniters are working, you may have a bad spark module. If one single burner is not igniting, the problem is probably the electrode.
If you have any questions, please let me know. Include your complete model number if it is different from the one you posted this question under. I hope this information is helpful to you.
Jan 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
    First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
    Oct 16, 2009 | Maytag Kitchen Ranges
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    GE Profile Gas Range oven light doesn't work even after changing
    Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
    64 people viewed this question
    Top Frigidaire Refrigerators Experts
    John Tripp
    John Tripp
    Electrolux
    Electrolux
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
