Question about Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher
Motor sounds like it's working OK, but no water is pumping.
Motor seems to be working, I can feel the fan pushing air. The problem is that not a drop of water is pumping to the spray arms. Do you think that I need a new pump and pump motor assembly? Or, is there a coupling between the pump and the motor that I can inexpensively replace?
    President:
  • Maytag Master
  • 2,651 Answers
You can give this part a try, 99003341 motor seal kit w/metall chopper,, comes with complete instructions on how to install
Posted on Jan 14, 2009
Onga house water pump
It sounds like the starting capacitor has failed. It is the round thing with two wires normally mounted on the outside of the motor. There is also a starting switch that could have failed but it is eaiser just to try the capacitor first.
Jan 21, 2014 | Plumbing
Burp cooling system how is this done
When you drain & refill a cooling system air is often traped in places like the heater core. If so the coolant level will appear full before it really is. To burp you need to add coolant till full or just over. Adjust the heater control to MAX heat. This will let full force of water pump to push air out of heater core. Fan speed dose not matter. Next start the motor & let it idle. As it warms up the thermostat will begin to open and close. This is when you should see fluid level drop as trapped air is pushed from system ( add fluid as needed). If this is working right you should fell quite hot air coming from heat vents. If air doesn't seem hot enough adding RPM by pulsing gas pedal should do the trick. And that should do it.
Jul 14, 2013 | 2002 Mazda Protege
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
Blower motor doesn't pump well even the fan switch on high
sounds like blower bearings are dried out and will eventually lock up the blower..sometimes you can spray wd40 in the blower bearings and it will work fine for a while.. also check vacuum controls to the baffle dors in the ductwork..may have some leaks there.. should hear a slight hissing if really bad..repost findings
Feb 09, 2013 | 2005 BMW 545i
Engine over heats
ck your water pump, sounds like no water movement,
Aug 18, 2012 | 1997 Nissan Sentra
Dded anti freeze, seemed ok for a day,started over heating again when moving but pull over at idle temp drops
Welcome to Fixya
Sounds like you have a problem with the cooling system. First thing you need to check first if the auxillary fans are working from the time you are the engine is overheating. If the auxillary fans is not working then the problem would be the aux fan itself or relays. if Fan is working then you might have a poblem with the water pump.
Thank you for using Fixya!
Oct 02, 2011 | 2003 Mitsubishi Outlander
My Ruud heat pump fan stops after running a minute. It is 10 degrees out now and defrost mode seems to work fine. It makes a humming sound when the fan gets stuck. Sometimes if I take a ruler to it, it...
The capacitor for the fan motor is bad...replace the capacitor and you'll be good to go...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Jan 23, 2011 | Ruud UBHC Air Conditioner
I have a Kenmore Elite dishwasher (model 630.17303406) and it just stopped working. Doesn't drain what's left in the bottom and just makes a humming sound when turned on. Power is good, sounds like the...
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 25, 2010 | Dishwashers
Refrigerator runs, not cooling
Sounds like you have a defrost problem. the easy way to check this is to turn the unit off for 24 hours doors open.
Then turn back on and if it starts cooling ok it is a defrost issue
Jun 06, 2017 | Kenmore Refrigerators
My heater on my F350 does not seem to be working properly. When I take my foot of the gas....the heater pumps cold air. What is my problem?
if the heater fan is sill blowing then the only thing is maybe the water pump is faulty. Feel the hoses if you can get to them for the heater core when its idling.. If one cools down when you idle and heats up when your reving up the motor I would suspect a coolant flow issue, I have seen heater cores clog or become restricted so reving the motor would push more hot water thru You may have a control valve on one of the heater hoses going to the motor that may not be fully opening .
Now it they are both hot and stay hot then I would heater box as being the issue, I wouldnt suspect the control as being at fault.
Dec 01, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher Logo
234 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
