Question about Yamaha DSP-A1000 5-Channel Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
  • add_augusto Jan 14, 2009
    where i could find the schematic diagram of yamaha amps model DSP-A1000
  • 85 Answers
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Posted on Jan 15, 2009
2 Suggested Answers
SOURCE: hi, i have a problem
My amplifier turns off after 5 seconds, what should I do to fix this problem
Posted on Nov 19, 2009
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
I'm looking for instruction manual for my amp Yamaha DSP A-1000 THANK YOU FOR YOUR HELP
The manual is available to download on the Yahama site (usa.yamaha.com). Click on the "support" tab.
Jan 19, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 , wiring details
Go to Yamaha's web site and download the user manual. It's free!
May 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Flashing LED on the volume
i have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Jul 19, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha natural sound A1000
manualsparadise.com has one - $19.50 gets you a download link for a zip file with the service manual.
Oct 12, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 5-Channel Amplifier Logo
350 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
