Question about Philips 50PF9731D/37 50 in. Plasma Television
42 plasma phillips trouble code D3V3
Sounds like powering up and after a few seconds sound like turn it off, open the back and review the trouble codes, green led flashes for code D3V3, what should I review? for fixing the code
  • 80 Answers
Check the power board for caps with the tops bulged up. 3300uf 10v I think.
Posted on May 31, 2009
My 60 inch phillips tv, I turned it off the other night and now all i get when i turn it on is the power button flashing green. 6 quick flashes and then 1. I need my tv, plz help
Try a new Web search for your brand. Try looking for a Diagnostic trouble code of 6-1 and see if you can pull up parts of a Service manual using that search routine. Try Phillips trouble codes, Phillips Diagnostic Codes, or your model# in the search.
It sounds like it went into a default Diagnostic mode. If you have a Remote with extra functions it may get you into the Diagnostic menu.
Dec 20, 2011 | Televison & Video
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Will not start when cold.
sounds like you have a weak power board, it could be a simple fix, its mostly to be weak capacitors, that will need replacing, you need to identify the faulty ones on the power board any that are rounded topped i.e not flat when looking from the side of them, they will need replacing with the same value i.e if they 16v 33uf then replace them with the same, also if the temp is on the 85c or 100c it dont matter but its best to replace them with 100c as they can handle more heat, as power board can get hot and over time the weak temp capacitors wear out due to the heat.
Apr 09, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
D3V3 Trouble code on Phillips plasma
I had the same problem with the same Model TV. after doing some research i found that i had 2 bad 3300uf capacitors. I made a video of the repair and posted it to youtube. the TV works great now! Check out my video! i hope this helps.
Dec 11, 2008 | Philips 50PF9731D/37 50 in. Plasma...
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50PF9731D/37 50 in. Plasma Television Logo
380 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
