Question about Sony KP-51WS500 51" Rear Projection Television
Blue shadows all of a sudden I get blue shadows on all channels. Any suggestions as to what is wrong. thanks, klmoore
  • Kyle Moore Jun 15, 2007
    I really don't know yet, but I called a local repair shop and they said their is a convergence problem of the colors, rather than a coolant problem, and they said 300.00 to 500.00 in price, which I am debating on whether to fix or not. The television is only 5 years old, was a floor model at Best Buy, and has a really good picture otherwise. Any further advice?
    Thanks for your help,
    klmoore
    New Friend:
  • 129 Answers
Coolant on picture tube need to be replaced hard job to do with not enough experience and knowledge , a tech can fixed 1 to 2 hour job with parts around 300.00 or less dependig on the tech.
Posted on Jun 13, 2007
  • Luis Amado Jun 15, 2007
    in the case that is just a convergence . 300.00
    its ok. no more than that
    good luck take care if you need more help let me know.
Red, green and blue shadows
have you tried to run auto convergence
Mar 08, 2013 | Panasonic PT-47WX49 47" Rear Projection...
Tip
Good day!!!I i had problems with the fl 231 fuse on my RCA D52W23 proj.tv....i...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 14, 2009 | RCA R52WH73 Projection Television
What is the issue when I see blue shadows (bulb or something else)?
it is called a convergence problem----set uses two stk chips for this and several sites on the internet sell kits for this type of repair.
Jan 08, 2012 | Sony KP-57WS500 57" Rear Projection...
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
Blue shadows
yes its the problem of convergence
and for reaar idea of what to replace on the main board and how to replace and how the components look and what is called what and what tools you require to do it yourself and how to fix it
please check the above link by clicking it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 21, 2008 | Sony KP-53XBR45 53" Rear Projection...
Blue Convergence
You will need to change the convergence amp ICs there are 2 of them they cost around 12 dollars each.
Mar 06, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Blue shadow and lines
This would apear to be a convergence issue ..sometimes you can go into settings and converge it manualy.. if this is to far out of range. a service tech will have to adjust inservice mode. if the convergence cuircits are not failing. if so then there are cuircits that will have to be replaced. is this just a blue shadow?.. is there green or red shadows. if not it may not be a major repair.
Dec 18, 2007 | Samsung HCN653W 65" Rear Projection...
Blue shadow
call tech ...suggest to ck. blue coolant..and c-chips.
Oct 30, 2007 | Sony KP-53V75 53" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
