Question about Insignia IS-DVD1001 DVD Recorder/VCR
What other DVD recorders will finalize my Insignia DVD's?
My Insignia DVD recorder is toast. I have many DVD's that I had been adding to as I went along, but are now left unfinalized. Where can I go or what can I rent or buy to finalize my discs? Will any Insignia recorder do the job? I don't want to waste my money ordering something that won't work.
  • 3 Answers
I had same problem, the laser is going bad. soon it will not read any disks.
and had many disks not finalized. so i bought a new one (jvc) and it does read the other disks not finalized. hope this helps
Posted on Jan 19, 2009
Can another Insignia DVD Recorder be used to finalize DVD's recorded on another Insignia DVD Recorder?
Unless the Insignia recorders are both IDENTICAL models, same year of manufacture, and have the exact same firmware versions, you CANNOT finalise a disc in one unit that was recorded on another.
Mar 06, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Can't dub from VHS to DVD on our blank DVD-R disks
Tries use DVD+R or DVD+RW best for DVD Players Recorder.Tries that DVD Disc.format first still can't do it.Come back i'll help u figure some else out.
Sep 04, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Trying to record tape to dvd
After recording a DVD in a DVD recorder you will need to finalize the disk. You should be able to put it in the original recorder and at least be able to watch the video.
If you are able to watch the video while you are recording then you should be able to record what you are watching. If you cannot see the video when it is sourced through the DVD recorder, then you need to adjust the input.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 23, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia DVD Recorder/VCR won't initilize disk
This problem sound like a component failure in the drive circuit of the dvd player. These type of intermittent problems are usually caused by overheating of the components. This unit should be taken into a service center and tested for bad components. This may be just the start of your problems if you do not check it out. You can call Insignia technical service at this number 1-877-467-4289. You can also check out their website in the frequently asked questions and troubleshooting sections to see if someone has had this problem and got the answer to it. www.insigniausa. Or you can just google it under insignia. Hope this helps you with your problem.
Apr 22, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
I cannot get the discs it records to play on any other unit, computer or otherwise. Without that, it is useless to me.
This problem was solved by reinserting the DVD and finding Finalize on the menu. Once it was finalized, it played fine in other machines and on the computer.
Thanks,
Mags
Feb 17, 2009 | Insignia NS-DVDR1 DVD Recorder
INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
Nov 21, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
Oct 18, 2007 | Canon DC210 DVD Camcorder
Insignia nr-drvcr
After you record, you must go to menu and finalize disc. Have you done that? jafreeb@excite.com
Aug 28, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
190 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
