Question about Whirlpool Refrigerators
Whirlpool refrigerator will not make ice
I have model GS6SHAXMS00 that stopped making ice. I saw that the water fill tube was frozen over. I cleaned it out and it made a full bucket of ice again. Once that bucket was full of ice again, the water fill tube froze over again. The ice maker still tries to make ice and I get water that sprays lightly out of the back of the water tube behind thefreezer. Please help. Thank you.
  • captainrybab Jan 21, 2009
    That worked great! Thanks a bunch!!!!
    Problem Solver:
  • 5 Answers
This is almost always due to a faulty shutoff valve. The valve is at the back, where the water line connects to the refrigerator. Turn off the water supply, remove the water line with a wrench. You should be able to take out the valve with a few screws and by removing one or two wiring clips and the plastic line on the other side leading to the fridge. A new one costs about $60 - $80 at a appliance parts store. Bring the old one with you, and the refrig. model number, and make sure the new one looks the same as the old.
The problem stems from the valve continuing to leak a bit of water to the icemaker after it fills the tray and shuts off. This trickle of water freezes and blocks the line, so matter how many times you defrost it, it will just happen again.
Posted on Jan 14, 2009
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Ice maker dosenot make ice will make if i fill
You have a bad water inlet valve OR frozen fill tube caused by a seeping water inlet valve (bad valve) .The water valve , is the piece the line from the wall connects to .
Aug 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker is not making ice
check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
Apr 05, 2009 | Whirlpool GD5SHAX Side by Side...
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Mar 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water not filling up the icemaker
it sounds as tho you do have solenoid prob.but it could also be an ice over sit at your water inlet tube that is situated near icemaker.
Jun 24, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
458 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
