The plastic coupler that holds the turn table to our Hotpoint microwave RVM1435 broke. How to I install the replacement part.
I cannot find a parts manual that gives these instructions
If you need a replacement turntable coupler, you can find this part listed as item number 942560 at repairclinic.com. Just type in your model number.
To replace, all you need to do is carefully slide something under the existing coupler (if you can) and pry up. The coupler will pull off the motor shaft.
If you cannot access the coupler due to the way it was broken, simply remove the bottom panel UNDER the oven. With the panel removed, locate the small turntable motor and loosen the mounting screws to remove. The coupler should be easily accessible with the motor out of the unit. Make sure you reinstall the turntable motor and bottom panel BEFORE you try to install the new coupler. The coupler needs to be installed from inside the oven cavity by placing it in the opening in the oven floor and pushing straight down onto the motor shaft.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
