Question about SanDisk Sansa Clip MP3 Player
Iam using sansa clip 2GB my system is showing device.. bt its nt showing songs in my ipod....
  • 3 Answers
When you plug it in and windows identifies it, you have to try to get to the file they are stored on, I believe it's a DVR file, if it's empty, try dragging and dropping an mp3 into it.
Posted on Jan 14, 2009
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
The screen of my Sansa Clip 2GB showed illegible signs two days ago when I last played it, but I could get songs playing. Through my computer I then cleared all playlists, deleted the songs etc. Then put...
Restoring your player can be done in 2 main steps:
>>1. For updating the firmware, the player should be switched to MSC mode.
This could be done through the menu. When not knowing what the display shows, use the forcing method in next link:
See the Sansa Clip steps below:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
>> 2. Once connected in MSC mode you can use the firmware updater when having Windows operating system, see next page:
For others who have MAC or Linux operating system you can not use the firmware updater: firmware should be manually downloaded from Sansa Forums and installed afterwards:
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Mar 03, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb not showing songs
Go to this guys tip it is a good tip on your problem, Fixya will not let me copy and paste, it so here is the link. Solve your MP3 Player Connection Problem.
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
2GB memory card problem
No dear .its nt japan .i have same 8GB pen driver but made in chaina befor am using it bt nt 8 GB 256 MB like that its show in 8 GB right? bt v cnt use 8 GB .try to contact kingston website if u have searial no may be they help u ..
Sep 13, 2009 | Kingston 2GB Secure Digital Memory Card
Hello i have a sansa clip 2gb and the music is showing up when i check the files but does not on the clip itself. it says "No song" I know i added the songs on there. can you help me?
try using windows media player to transfer the's how 1.Update WMP to version 10 or 11 2.goto sync tab and yoyc player must be detected. 3.create a playlist of songs you want to transfer on start sync to transfer music to your player.
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
Old songs dont show
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
Jun 03, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip 2gb has only 60 songs on it,but it says that it is already completely full.I've tried erasing everything and reseting it. Even with no songs on it it claims that 1.5 gb have already been...
What i would recommend you to do is to format the device and transfer all the songs over..There might be a corruption on your device operating system...and format it should solve the problem you are having..
Thank you
Mar 04, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB MP3 player
The user manual wil lshow you how to switch your USB mode from MSC to MTP:
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB won't transfer songs
I had a similar problem with with one of my mobiles, so not sure if it applies in this case, check the ports, and make sure the device is connected to the correct usb port that the pc has allocated to your portable device (sansa clip)
Sep 17, 2008 | SanDisk Sansa Clip MP3 Player
Sync to player and memory card without duplicates
I got this from: Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
