Question about Kenwood Excelon KAC-X541 88W x 4 Car Amplifier Car Audio Amplifier
Kenwood steroe wont turn back on after few days of working
Steroe wont turn on again after a few days of working. took it out of the dash and checked the wires and wont turn on...its brand new
    Problem Solver:
  • 9 Answers
Check the fuse on the back of the radio, as well as the circuit fuse sending power to the radio
Posted on Jan 15, 2009
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
Wont start/turn over clicks when turn key/battery good
If the battery is good as you state. then the starter must be at fault, if you can reach it give it a light tap with a hammer and try again. if this fixes it you need your starter replaced or repaired.
Jan 17, 2013 | 1996 Honda Accord
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Jan 12, 2013 | Kenwood KDC-128 CD Player
Kenwood in dash reciever will not read compact disks or USB
The problem is definetely a fault in the Mp of the set as it is not able to process the data from the flash memory or the CD. If will be good to open the set and do a through check for loose connections, faulty ground or joints inthe main PCB. Remove dust and fix back, Also clean your optical lens and drive unit. Fix them back and check again . If it works you are lucky or else the main processor is faulty. Hope you try this Good day
Jul 26, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Lockd stero
Codes are set by the user, so if you do not have the code then it will not work. I do not beleive there is a way to reset them other than possibly contacting Kenwood directly.
Mar 01, 2009 | Kenwood Car Audio & Video
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Hey jeff about the kenwood
In standby you have to hold menu doen untill menu appears on screen, Scroll to aux and turn it on :)
Don
May 21, 2008 | Kenwood KDC-135 CD Player
T-mobile dash wont turn on
In my experience when getting a phone wet your only choice is to let it sit. It could take a few days or a month but soon or later they usually fire back up.
Dec 14, 2007 | T-Mobile Dash Smartphone
Kenwood Excelon KAC-X541 88W x 4 Car Amplifier Car Audio Amplifier Logo
187 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
