Question about Optoma EP716 Multimedia Projector
Optoma EP716 lamp comes on for 10 seconds, then goes off.
Recently purchased a used Optoma EP716. The unit powers up, the fan comes on, and the lamp comes on for about 10 seconds then goes off. The fan and power light stay on. I tried putting it in front of a powerful fan (to see if it was temperature related) and it didn't help. I also took off the outer housing and put the fan on it to get more air flow, and still no change.
  • 1 more comment
  • soliver1101 Feb 02, 2009
    It's not the lamp. I finally found someone with a working EP716, and my lamp works fine in their machine.
    In watching the working machine, it seems that the lamp comes on fairly dim for about 10 seconds, then flickers, gets brighter, and the picture appears. With my machine, the lamp cuts out at that time.
    Any other ideas?
    Could it be the ballast?
    I've disassembled the unit, and there's no noticeable dust anywhere. The working unit has a LOT more dust in it than mine.
  • 6,784 Answers
Ok, this is defiantly the temperature regulator. this is an integrated part on the circuit board. it may have been damaged by the previous user. sometimes the resellers only check to see if it works for just a sec then, they put it on the shelf like its new. this unit should of never been sold without this repair. the good news is, it is repairable but, you will need to send it to a local technician for hands on repair or, repackage and send to the manufacture for a rebuild. i would see if the store owner will either repair it for free or, refund your money. hope this helps:) thanks fo using fixya!
Posted on Feb 02, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Not one Person Asked you to Check the Balist for the Bulb. The Balist in your TV for the Bulb is Out and will need to Be Repaired. I would suggest an Authorized Service Center for this Repair. Please Rate My Response! Thanks!
  • Travis Humphries
    Travis Humphries Feb 02, 2009
    Absolutely. This is your Problem.
    Genius:
  • 2,035 Answers
You try other machine lamp in your projector and check it gives the same results ..if its yes there a problem in the unit itself you may need to get it serviced ..........as they are not user serviceable parts ...
Good luck...
  • 744 Answers
Hi... the faulty portion is not in ur light or in ur fan as u have clearly mentioned that it works in other devices.. So the major problem might be in ur unit...The reason may be due to some minute dust formation...TRy to clean up ur device and then try back...
  • Prakash Ram
    Prakash Ram Feb 02, 2009
    hi... so therfore the part where u would fix the bulb would have got repaired.. so its better to replace that rather than replacing a new bulb...
  • 15,935 Answers
Only thing that i can think of would be bad lamp driver board which would be located in the power supply circuit or a defective lamp from the manuafactuer . This sometimes happens where you buy a lamp and it comes defective right from the box.
  • 2 more comments
  • blueextc3221
    blueextc3221 Feb 02, 2009
    but you state it is not the lamp, so look at the driver board for any cracked solder joints which may seperate as it heats up. Otherwise, without a layout and parts list, it will be a complicated fix.
    From what I hear, OPTOMA is not keen on customer service.
  • blueextc3221
    Thanks for using Fixya - a Fixya rating is appreciated!!
  • blueextc3221
    If you do have access to a meter you could check the ballast to see if it's putting out enough voltage for the lamp.
    Also - I would suggest checking the fuse. There is an internal fuse... that on appearance may look good, byt after heating up - the element no longer makes contact due to thermal expansion.
  • blueextc3221
    Low Voltage DC Ballasts must generate the required voltages to start and operate the lamps reliably as well as to assure long life.
    The ballast may be obviously burned and smelly, overheated, or have a loud hum or buzz. Eventually, a thermal protector built into many ballasts will open due to the overheating (though this will probably reset when it cools down). The fixture may appear to be dead. A bad ballast could conceivably damage other parts as well and blow the fluorescent tubes. If the high voltage windings of rapid start or trigger start ballasts are open or shorted, then the lamp will not start.
    Ballasts for fixtures less than 30 watts usually do not have thermal protection and in rare cases catch fire if they overheat. Defective fixtures should not be left operating.
    Electronic ballasts including those in Compact Fluorescent Lamps (CFLs). These are basically switchmode power supplies and a total failure must be diagnosed with that in mind (including the SAFETY issues!). However, the most likely problems with mass produced and cheaply made electronic ballasts - especially when heat-stressed in enclosed or semi-enclosed fixtures - are cracked solder joints. Going over all the solder joints on these at the first sign of any flickering or other erratic behavior may prevent subsequent This is the only type of electronic ballast failure that it probably makes any sense to spend time on if your time is worth anything.
    Hope I was able to shed some insight on your problem.
    Thanks for using FixYa - a FixYa rating is appreciated!!
    Scholar:
  • 160 Answers
Its the faulty lamp according to me so it doenot stay on for longer time.
Posted on Jan 17, 2009
    Sergeant:
    Scholar:
  • 199 Answers
How to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
just remove the lamp and reinsert the same lamp again and check out.if it still gives the same problem .then replace it with new lamp.
    Sergeant:
  • 221 Answers
Its the problem of the lamp and needs to be replaced.if the unit is new get it replaced.
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use a screwdriver to remove the screw from the cover.
  5. Push up and remove the cover.
  6. Remove the 2 screws from the lamp module.
  7. Pull out the lamp module.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716 was making a clicking sound and now doesn't turn on... Any ideas?
Clicking is probably the lamp trying to start - it uses an electric arc to get going. Kind of like gas stoves using spark to ignite the gas. Odds are that the lamp is dead. If there are any indicator lights, and you describe them, we may be able to confirm (or disprove). 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Jun 17, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
OPTOMA EP716
ALSO CHECK YOUR FAN. IF THE FAN OR A HEAT SINK IS NOT WORKING PROPERLY (I.E. THE FAN MAY JUST NEED TO BE CLEANED OR REPLACED, THERE SHOULD BE A SMALL HEAT SINK. IF CLOUDED W/DUST, IT WILL KEEP THE OPERATION SHORT). ALSO CHECK IF YOU HAVE SET ANY TEMPERATURE SHUTDOWN PARAMETERS. IF YOUR LAMP HEATS UP FOR SO LONG AND REACHES A TEMPERATURE THAT WILL AFFECT THE CIRCUITS, THIS OF COURSE WILL SHUT DOWN YOUR UNIT UNEXPECTEDLY. HOPE THIS HELPS...JGUAM
Jan 12, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
219 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
