Question about Acer Aspire 3680 Laptop
Acer Aspire 3680 will not detect hard disk. In command prompt where should be, there is
  • 1 more comment
  • Anonymous Jan 17, 2009
    My aspire 3680 does not start in XP - will not boot up - any trying to reboot 20 + times if lucky she will run windows again or I need to push the F1 or F2 bottoms and simply pray it works. Some help / guidance is much appreciated here
  • Calvinrueb87
    Calvinrueb87 May 11, 2010
    what type of boot disk are you using? have you checked the available partitions with fdisk? have you checked the bios to see if the hard drive is registered with the system?
  • Verne Koti May 11, 2010
    hard drive failed
    Sounds like its time for a new one
    no Operating system loaded (XP or VISTA or MAC)
    Might be able to unplug this drive and try another computer to see if your drives contents are accessible then copy them to another drive before it dies completely.
    please let me know thanks
  • 476 Answers
Hi there,from the sounds of it this lovely little excercise is due to the hard drive failure,either that or no OS - XP disk is dead or damaged.
If you have the original restore disks from the 3680.
You could try reinstall and test from there,If your contents were important then try to remove hdd take to another computer and see if the drive recognises on the other machine,
If it allows access ,copy all your settings and documents straight away because it could die shortly,hopefully not tho....
Once the back up of your docs and settings and hdd back in your computer then use the restore disk to revive your machine,
This process wipes the C Drive and does a complete reinstall of all the required softwares and in the correct order too...
It should take 15-20 min to load onto the machine and about 40 minutes to reinstall all the RESTORE to Factory Defaults Settings.
Just let it do this process from start to finish and it should eject disk when done and reboot by itself.
when it starts up again it will be back to the windows activation screen and the ready to start loading up if your have the original restore disc,
Once your happy with it and its working,
How do I create a restore point?
This will help you return to the point when everything was working,
If you should'nt encounter any more problems,
There may be a Hidden Partion on your hard drive that may allow you to restore from that.Then all thats needed doing is the bios settings will need to be changed to select the XP CD on bootup or the hidden partion on bootup then select save and reboot,It should be straight forward from there.
Just about finished,
Dont for get to do your windows updates for SP2 and then turn off the update functions.
And BACK UP the new install to DVD blank so you can restore
any other time you have issues
I hope this helps but that should cover itn for you,
If you need more help please let me know.
Thanks Misterdj
Posted on Jan 20, 2009
Fix acer aspire 3680 hard drive
First go to start and type cmd in the search box
select the command prompt
type the following command in the command prompt
After scanning the the disk restart your computer
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files and fix registry and windows errors
Best of luck
Jul 02, 2013 | Computers & Internet
Error in c :\user\many\appdata\roaming\rasctrnm4.dll missin entry fmqw
Insert operating system disk in drive.
Click Start. Click Run. Type
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. after this run reginout intel partner to fix the registry and then open c
Oct 01, 2010 | Acer Aspire 3680 Laptop
It is an acer aspire 3680 laptop. when i power it on it says the acer screen and then it goes to a command prompt and say that the operating system is not found. please help me.
if youre sure you have an OS first ,,then go into bios settings(F2 whilst booting) and see if correct boot sequence is enabled,navigate with"tab"keys/arrow with "enter "key
save and exit once you are familiar with these pages
Sep 10, 2010 | Acer Aspire 3680 Laptop
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
How to format acer 3680 vista laptop
You should have a restore cd. If not you can boot to dos and type from a command prompt:
C:\> Format C:
Nov 22, 2009 | Acer Aspire 3680 Laptop
My acer 3680 is not detecting my wiresless router connection and I can not get online. I know the router works. How do I set it up to get the connection.
you can configure the wireless settings of your router first by going into it's GUI. to go there just open your command prompt and type in ipconfig/all, then look for Default Gateway. open an internet exlporer or any browser and type in the numbers you found in the default gateway in the address bar. when you're done configuring the wireless settings of your router you can now try and connect to your wireless network...
hope this helps....
Nov 10, 2009 | Acer Aspire 3680 Laptop
Start up problem with xp
u have to repair your operating system with winxp recovery disk.
Mar 14, 2009 | Acer Aspire 3680 Laptop
Maybe is a software problme ????
While booting up, just after BIOS lists computer peripherals (prior to WIndows logo), press F8 repeatedly. In the menu pick Safe Mode (Command Prompt). If the blue screen of death doesn't appear, type chkdsk /r and hit Enter. This might fix some hard disk issues that were preventing normal boot up.
Jan 16, 2009 | Acer Aspire 3680 Laptop
Password help
please elaborate on main password, do you mean windows password? if so: 1) download a password reset disk (I can create one for you and email it) for a small fee. 2) boot laptop, when you see acer power on logo, look on screen for recovery or setup. Most likely F2, F6, F10, or F12 key. That will bring you to an Acer recovery menu. You can restore the laptop to factory, however you will lost all your personal data, and will haver the factory loaded software .
Aug 29, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
