Question about Kyocera FS-3900DN Laser Printer
Kyocera fs-3900DN Kyocera printer says "Paper tray full" when I go to print and printer freezes... Turn off printer and then back on, it's ok until I go and print and the same fault comes up... Thanks
  • 2,120 Answers
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Posted on Jan 23, 2009
  • bincbaby Feb 25, 2011
    There is a black tab on the top of the printer where the paper comes out, that may be stuck up. Push it down and you should be good to go.
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
May 28, 2010 | Kyocera FS-3900 DTN MONO LASER PRINTER
Printed paper path
sure...check your print manager settings, first, to see if that exit tray is selected as default..
Mar 15, 2008 | Kyocera FS-C5030N Led Printer
-Laser Printer printing NEAR blank pages\
if this is an fs3900 tray rerunning the developer thru the machine.
Do this by going into the menus..up and down untill you see others..than right up and down untill you see service...right arrow..than up and down untill you see developer..once you see developer hit enter twice...power off than back on will than recoat the mag roller with toner...good luck
Jan 30, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
Wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Jun 23, 2009 | Kyocera FS-3900DN Laser Printer
I am getting Call Service 7410:00 32266 on FS-3900DN Kyocera Laser Printer.
You have pulled the drum unit out of position possably after changing the waist toner ? Open the back cover, open the frunt cover and remove the developer unit, the full unit not just the toner, open the side cover where the waist toner bottle is and push the drum unit back into place until it clicks, put the dev unit back in place and close everything reboot the machine
Apr 18, 2009 | Kyocera FS-3900DN Laser Printer
What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
Mar 26, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
389 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
