Sapphire RADEON® X550, (128 MB) PCI Express Graphic Card Logo
memet akinci Posted on Dec 14, 2012
Results for "x 550 512mb hm pci-e vga tvo dvi-1 w 128m vram"
1helpful
Pilot Sapphire 256MB Radeon 9550 256MB DDR VGA TVO DVI-I AGP
Hello you can download the driver here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
Select desktop graphic
Next radeon 9xxx series
And next the 9500 series
And select your windows system.
click on display results, and the driver should be available for download.
Good luck
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Gjerg
Please re-submit your problem with more details to describe what is the issue. Thank you.
1helpful
Looking for a new video card for this model, having trouble finding one that will fit, any ideas?
any low profile video card with do. Try the following:
A) XFX NVIDIA GeForce 7300 GS Low Profile (Part # PV-T72G-WAN7, PV-T72G-****) $55
B) Visiontek Radeon X1650 Pro HD Low Profile (Part # V261-4038) $70
C) MSI NX8500GT-MTD256EH GeForce 8500GT 256MB 128-bit GDDR2 PCI Express x16 HDCP Ready SLI Supported HDMI HDCP Silent Heatsink Video Card - Retail $76.99
D) Leadtek WinFast PX8500 GT TDH Low Profile $131 (Available in Passive or with Fan versions)
E) Sapphire ATI 256MB X1600PRO HDMI PCI-E (TVO, DVI), Low profile (brackets included) $139
Does the Sapphire card need to fit perfectly in all the slots on my motherboard
Hello
The Video card will only fit in the pci express slot on your motherboard.
Usually there is a small latch that needs to be pulled down,then insert the card then pull latch up.
http://quicktiming.org/wp-content/woo_custom/30-pcie.jpg
Check out the picture.Its the pcie 16x slot you want to install it in.
1helpful
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
3answers
I have a new graphics card and the connections dont match
the motherboard might be VGA, and the card PCIE, the connectors will not match, more info is required, better still check motherboard specifications, and look for the right type of graphics card.
No reboot and no screen.
hi jsc,
try to use the VGA port again so that we can isolate the problem. hold the power button down for more that 5 seconds.
Top Sapphire Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sapphire Computer and Internet Expert? Answer questions, earn points and help others
