Question about Radio Communications
2 cb's 1 antena ???
I have 2 boys that want cb' in there rooms. Can I hook both cb's to 1 antena ? or will it feedback into one when the other is keyed-up?
How can I solve this problem and keep them both happy???
Thank You,
Mike
    Sergeant:
  • 233 Answers
You cannot use one antenna on 2 units, the output power will hurt the other radio - not to mention greatly affect your standing wave radiation, greatly decreasing your range. You will have to run 2 antennas, but make sure to keep them as high as possible and at least 6 feet apart.
Posted on Jan 14, 2009
Feedback through speaker during transmit
ARE YOU TALKING ABOUT THE INTERNAL SPEAKER IF SO THE WIRES TO THE SPEAKER INSIDE ARE BEING SHORTED TO GROUND TOUCHING SOMETHING METAL
Feb 24, 2013 | Radio Shack TRC-503 CB Radio
Hi. This Sansui 40 inch was working fine with an antenna. The Boy hooked up his playstation 3 and now it doesn't get any channels. Checked all the connections, disconnected the PS3, Tried doing th
You likely need to add an antenna amplifier. The PS3 should have been hooked up to one of the other source inputs other than the antenna. If it was attached via the antenna, a solder connection may have come loose or the coax got kinked.
Feb 20, 2012 | Radio Communications
I bought a new antanea 3 ft fiberglass with mirror mount when hooked to radio needle swings all the way to the red and i dont transmit or receive but when hooked back to old antenae works fine old antenae...
Mirror mounts need alot of Ground to tune correctly. Most mirrors don't ground to the door good enough, not to mention the reflection of the radio signal off the cab. Be sure it's grounded good and the nylon insulator is place.
Jan 14, 2011 | Cobra 29 LTD CB Radio
Have k40 antena in my 29 ltd cobra and i cant get less then 1/2 mile signal
Hi, my name is John. A K40 is a great antenna. Make sure you have it in a good place, such as top of vehicle, a good ground, and SWR checked, they can check it for you free at Radio Shack or CB shack.....if that does not do it, let me know, it could be something internal....hope this was helpful....
Aug 29, 2010 | Cobra 29 LTD CB Radio
Tried to used CB without antena
If you were trying to transmit without the ant. then your assumption about the demise of your radio is correct.If you hooked it up using an inline fuse ,then just change the fuse. If you hooked up without a fuse, then no, you can not fix it. Please rate this answer.
Apr 09, 2009 | Cobra 29 LTD CB Radio
GREAT TRANSMISSION HARDLY NO RECEPTION
need to take it in to have the SWR set on antena
Jan 22, 2009 | Cobra 19 DX III 40-Channels Base CB Radio
2 cb's 1 antena?
It would be best if you had seperate antennas. You can put a mobile antenna on each radio. Or else you are getting into expensive splitters,etc.
Jan 14, 2009 | Radio Communications
Non grnd steel antena
I assume your coax is not hooked up properly or you have some kink of a short in your antenna connection ( thats if your cb is working properly ) Radio Shacks Information that suggested that the 102" whip is the perfect antenna is their opion only as I prefer to recommend a full wave antenna system to my customers, but I do assure you, the 102" whip does work well if it's properly installed. I have found the main problem in the 102" whip installation is when the center hole is cut to install the antenna, it's not cut big enough, which grounds the antenna. It's not suppose to be grounded in any fashion to the automible chassis. The ground of this antenna comes from the 3 screws mounted around the outside of the antenna mount. Check that for sure. If you can't correct the problem. write me back at this web sight of direct at wyoed1@aol.com. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Cb feedback though external am/fm speakers
Hi Big OX,
Terrible problem.  I know what your going though.  Route your AM/FM Antenna wire, and Speaker wires separate from the  CD Antenna cable and power supply wires. If you can,  twist the speaker wires.  If the Speaker wires are run along side the CB Antenna wire for a short distance, you will pickup feedback. If you much have the Antenna wire get near the speaker wires, have the antenna wire cross the speaker wire at a 90 degree angle. Try not to run the antenna wire in paralell with the speaker wires.   Good luck
Oct 27, 2007 | Car Audio & Video
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
